R50/53 A squealing sound.
Old Feb 9, 2022 | 05:37 PM
tHeFastEsTtUrTlE's Avatar
tHeFastEsTtUrTlE
A squealing sound.
Hello to all that stumble upon this thread. I drive a ‘05 MCS w/ a 6 speed manny tranny, and w/ 128,xxx miles. The issue is a squealing noise that occurs when I’am driving below 30 mph. Only at that speed does the annoyance occur. Anyone have a clue, or can declare where the issue is coming from before I swap this, and swap that, and the noise persist to lurk.
Old Feb 11, 2022 | 12:34 AM
AcidK1's Avatar
AcidK1
Usually squeeling would be belt related. So I would check there first, belt condition, shiny belt will cause squeel. Pulleys siezed of not in line with each other.
Without a bit more specific info its hard, could be brake pads worn down, whole number of things.
Could do with knowing things like,
front of back
Left or right
Any other noises going on
Old Feb 11, 2022 | 07:32 AM
Panzu's Avatar
Panzu
front of back
Left or right
A video for the sound could also be pretty helpful
Old Feb 12, 2022 | 01:53 AM
tHeFastEsTtUrTlE
It is not the belt. I’am certain about that. This squealing noise sounds like it if were the brakes, but I had replaced them. Front, and rear along w/ front, and rear rotors. I hear the sound coming from the front side of the vehicle, but like any noise it may come from the rear ? Like I mentioned. The sound only occurs when I’am driving at a low speed. Exactly 25 mph, or below.
Old Feb 12, 2022 | 05:56 AM
cooper48's Avatar
cooper48
Could be the idler pulley. Or, since you recently replaced the brakes did you use anti-squeal on the pad backs?
Old Feb 12, 2022 | 05:58 AM
DFTR's Avatar
DFTR
Wheel bearing
Old Feb 12, 2022 | 11:10 AM
tHeFastEsTtUrTlE
Originally Posted by DFTR
Wheel bearing
I did not use anti squeal, but some brake lubricant on the back side of the pads to absorb vibration. Excuse my ignorance cooper48, but may you explain to me more about the idler pulley in how it can be a source to this squealing noise my turtle has developed ? DFTR I had conceived the notion that it has to be a wheel bearing. I’am going to inspect any abnormal motion on the tires to detect which one ? Thanks for all of your replies, and suggestions. I’ll update for any solutions. O, cooper48. Don’t forget to educate me on that thought of yours. Keep motoring !
Old Feb 12, 2022 | 02:31 PM
cooper48's Avatar
cooper48
The idler pulley helps maintain tension on the serpentine belt. It has a bearing in the center that can fail and create noise/squeal. The best method to check for this is to remove the serpentine belt and turn the idler pulley by hand. If it is faulty it will either wobble or make noise. It's affixed by a single bolt through the center and the pulley is easy to replace. It's number 3 in this link: https://www.realoem.com/bmw/enUS/sho...diagId=11_3394
Old Feb 13, 2022 | 07:47 PM
ssoliman's Avatar
ssoliman
Does it relate to engine speed or wheel speed?
Old Feb 14, 2022 | 02:21 PM
tHeFastEsTtUrTlE
Wheel speed.
Old Feb 14, 2022 | 07:02 PM
ssoliman's Avatar
ssoliman
Originally Posted by tHeFastEsTtUrTlE
Wheel speed.
ok. I’d say it’s bearing or brakes then
does sound change or go away when you apply brakes?
get up to speed where noise is present, then apply brakes lightly, w left foot, keeping speed constant with right foot on throttle…
Old Feb 15, 2022 | 05:06 AM
tHeFastEsTtUrTlE
The noise stops when I apply the brakes. Like I mentioned before. I’ve replaced front, and rear brake pads, and rotors.. But I’ll try your method, and go from there. Thanks. I’ll give a solution soon, or later.
Old Feb 15, 2022 | 05:42 PM
ssoliman's Avatar
ssoliman
New retainer clip thingy for the brake pads might help
Old Feb 16, 2022 | 11:16 AM
AcidK1's Avatar
AcidK1
Try pulling the handbrake up a click when it's making noise, if it stops it's probably the retaining spring on them, if it still makes noise look at the front
Old Feb 16, 2022 | 03:53 PM
ChiefM's Avatar
ChiefM
It could be some glazing on the brake pad. Take them off and do some light sanding.
Thunderbirdpilot
Mar 29, 2020 02:38 PM
Brianjager
Dec 11, 2012 08:51 AM
chava007
Sep 24, 2009 02:50 PM
andromcs
May 21, 2008 07:23 PM
drosne01
Aug 3, 2007 08:49 AM
