R50/53 xenon to halogen housing
Old Dec 15, 2021 | 07:50 PM
Vafren's Avatar
Vafren
ok so I've been looking for an answer and I'm probably just dumb but i have been unable to find it. i have the factory hid option on my 2005 mini S. problem is the lenses are a lovely shade of yellow that will not clean and i am trying to make the car look a little more presentable. that being said I don't want to spend the 600$ a side for factory replacements, and instead i would like to use these.
https://www.ecstuning.com/b-helix-pa...ini01hl-b~hlx/
does anyone know how to do a swap and if i need anything specifically.
thanks so much in advance!!!
Old Dec 15, 2021 | 09:17 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
They will work. Only issue will be you will loose your auto leveling feature of you xenon headlamps.
Old Dec 15, 2021 | 09:23 PM
Vafren's Avatar
Vafren
oh? So I can just plug and play?
Old Dec 16, 2021 | 04:43 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Yep,
simply plug and play.
I did the conversion on my 2006:
https://www.northamericanmotoring.co...ml#post4552265
In my case it was for aesthetic reasons with a side benefit of slight weight savings.
Just an FYI, those Helix units you linked to have been on backorder for quite a long time, so may want to contact ECS and ask if they may know an ETA.
Some places list them as No Longer Available.
As an alternative choice for you to consider,
many people have had good results with polishing the lenses:
https://www.northamericanmotoring.co...ml#post4491411
More threads here on NAM about that topic, just found an example quickly that has a good pic.
Old Dec 16, 2021 | 09:00 AM
megaDan's Avatar
megaDan
I've restored a handful of yellow lights. They may not go back to 100% crystal clear; but they will be more than presentable and I think you'll be pleased with the results.
Potato quality pictures, but you get the idea:
Before
After
In the sun
Old Dec 16, 2021 | 09:08 AM
ChiefM's Avatar
ChiefM
Use chemical guys headlight restore. It's awesome stuff and for best results use a rotary buffer.
Amazon Amazon
Old Dec 16, 2021 | 10:36 AM
Yep we are still waiting for them to come in, they have been on BO for a while. The factories in Taiwan closed/down temporary. So it hurts most all aftermarket lighting unless its like Hella, PIAA, MM, or AL lighting which are OE and most made in Europe.
You can use some headlight restore stuff we sell, works great, just have to do it once a year.
https://www.ecstuning.com/b-osram-sy...kit/38771~osr/
https://www.ecstuning.com/b-chemical.../gap11516~chg/
MiniManAdam
Apr 22, 2020 12:00 PM
AbusedR53
Sep 25, 2018 05:50 AM
illzoni
Aug 25, 2016 07:55 PM
n2000snake
Dec 8, 2014 06:51 AM
Wake|MCS
Oct 27, 2006 05:33 AM
