R60 Headlights
Old Sep 3, 2014 | 04:32 AM
n2000snake's Avatar
n2000snake
Headlights
SO I currently have the stock halogens with aftermarket HID'S... I know Its a big deal trying to change to the factory xexons, ( dealing with coding and all) Do any of you guys think its possible to buy a xexon headlights remove the inserts and place them in the halogens casing, and using the factory halogens wiring? I would still be using my aftermarket HIDs.. What are your thoughts
Old Sep 3, 2014 | 05:52 AM
The X Men's Avatar
The X Men
If you are using an aftermarket HID with factory reflectors, you will cause all kind of glares for the other drivers on the road. I am not sure if you can retrofit a factory projector into the reflector housing. It will involve removing the lens and backing it back on. Its not a job for the novice.
Old Sep 3, 2014 | 06:57 AM
n2000snake's Avatar
n2000snake
Thanks for the info, I have taken headlights apart many times, I was going to remove the entire inserts on the projector and place in the halogens
Old Sep 3, 2014 | 07:32 AM
The X Men's Avatar
The X Men
Sounds like you have experience doing it, all you need to do is find a projector that will fit into the CM's halogen assembly. Please post some pics of your mod.
Old Sep 3, 2014 | 10:59 AM
n2000snake's Avatar
n2000snake
i was purchasing 2 damaged countryman xexon headlights remove the inserts and install them in the halgons
Old Sep 3, 2014 | 01:17 PM
The X Men's Avatar
The X Men
Let us know how it turn out. Doesnt the CM have bi-xenon? How will you operate the high beam shutter?
Old Dec 8, 2014 | 06:51 AM
See here for the new Countryman and Paceman Xenon retrofit kit : Factory MINI
https://www.northamericanmotoring.co...r-r60-r62.html
OutMotoring
Mar 3, 2017 06:29 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
