R50/53 Wideband sensor after pre-cat
Hello ,
I purchased an aem afr guage to help with my afr readings since I have put a few mods on my 2004 mini cooper s and to help with dialing in with the tune.
I know people reccomend placing wideband before any cats. My question is could it be run after the pre-cat on a oem r53 manifold ? ( between pre-cat and stock cat)? Would the readings be totally off or just minimal? I am curious as when they do dyno tuning dont they run the wideband on the tailpipe?
Thanks a million
Thanks a million
Hello ,
Thanks a million
Thanks a million
Yes I understand that the wideband is much more accurate before any cats. I am still curious as to how does a tuning shop do afr readings when tuning via the exhaust then? Woulnt the afr values be off? I am trying to understand how much more difference the readings would be between sensor being before the pre- cat or right after the pre-cat. Are we perhaps talking a 10% variance or more like 40 to 50 % off ?
Thank you
Thank you
From what it sounds like, you're just trying to compensate your tune for the new mods... putting the wideband between the cats will be fine for that.
tail pipe sensors are ok at best, wideband after cat can be up to a full point off it depends on how close to stoich, flow, and the cat not all are equal.
If welding a bung on, just do it right.. There is room right next to the stock bung just point it the other direction. That said the stock header is garbage do it all the way right and put a 4:2:1 or 4:1 on, they are cheap now. Go with obx thing graphite header gasket not the ones that look perforated. Summit has a nice 4:2:1 that also gets rid of the dumb flex pipe and puts a proper donut on
It's less accurate, but can get him close to a good tune.
If a dyno is tuning via exhaust with a wideband probe, they'll get you a solid tune. But, if you want the BEST tune, you mount the wideband pre-cat.
As for the summit racing 4-2-1 manifold are u referring to the xforce? I was actually considering a manifold if my stock one has to be dropped anyway. I was looking atbthe obx and scorpion , but they both have gone up quite a bit in price especially having to ship.it out of usa. Do u run the xforce and are u happy with the quality and fitment out of the box. ?
as for the header gasket u recommend, is it available on summit also? Can't seem to find it ?
are u running decat or with cat? Did u find the car got way louder with the manifold? Will probably be welding the manifold to the stock cat and didn't really want to make the car loud . Currently have stock manifold and cat to magnaflow catback exhaust
Can it be ran between the pre-cat and main cat, and still get a reliable and good tune... yes.
Should it be ran prior to the pre-cat... also yes.
Drivetrain MTX-L yellow wire to replace stock o2 sensor
MrBlah
Mar 15, 2019 06:03 AM
Drivetrain Please Help: New Header / O2 Sensor problem
HoosierDaddy1
Jan 27, 2015 07:39 PM
