R50/53 Foxwell NT510 can't communicate with body modules
Old Feb 4, 2026 | 10:35 AM
  #26
MikeW2's Avatar
MikeW2
I ended up returning the scanner and I setup INPA. Cool stuff.
Old Feb 4, 2026 | 10:53 AM
  #27
Here2Go's Avatar
Here2Go
NAM Community Team
Originally Posted by noodlesandsam
If you disconnect the seat / airbag when the battery is still connected, you will trigger the airbag light - which is all in the airbag module / ecu - not engine, transmission or body module / ecu. I have used foxwell 510 to reset that - twice on the e46 - interior swap.
Originally Posted by ssoliman
inpa will reset airbag light if the condition has been fixed.
with the srs, the lights dont reset on their own. once there is an error you have to reset it manually. some safety kind of logic
Originally Posted by Tombstone
. I think the Foxwell 510 is the same as the Swaben Elite but, I wasn’t aware it could reset the airbag module , Thanks …
Funny thing is; I originally had the Creator BMW 110+ when my BST mysteriously blew and set off the air bag light and thought it couldn't reset it. So I bought the Foxwell NT510 Elite. After reading and performing the diode hack on the airbag/BST - The airbag light went out by itself. So I didn't really need the 510 after all. But it has been an indispensable tool nonetheless.
Old Feb 4, 2026 | 10:58 AM
  #28
Here2Go's Avatar
Here2Go
NAM Community Team
Sorry to hear about the Foxwell scanner but I wish I had INPA or ISTA too! As I understand neither one is easy to set up by a novice (aka: me), and often hear the interfaces are written in German (?)...
Is that true?
Old Feb 4, 2026 | 11:23 AM
  #29
ssoliman's Avatar
ssoliman
its not hard to do. step by step guide below. i think all the downloads are still available.
post #16 has EVERYTHING you need
https://www.northamericanmotoring.co...3641-inpa.html
Old Feb 4, 2026 | 12:28 PM
  #30
MikeW2's Avatar
MikeW2
I did it using Mike's Easy BMW Tools package. Easier in my opinion. You need to update two folders/files after the installation to have it work with a mini cooper. I also recommend setting up Windows 7 32bit as a virtual machine (via e.g Oracle Virtual Box) so you don't need to have a dedicated laptop for it. Make sure to setup you cable driver properties to COM1 and 1 ms. Strongly recommend using Chatgdp as support, you will be surprised how good it is. DM me if you have issues, I'll try to help out as time permits. Good luck
Old Feb 4, 2026 | 03:08 PM
  #31
Here2Go's Avatar
Here2Go
NAM Community Team
Hey Thanks @MikeW2 & @ssoliman ,
I followed ssoliman''s link and I managed to get INPA loaded and working. Although I was happy to see it is written in English - have little idea of what I'm doing.
I noticed there was a selection for R50, R52,R53 but only specs for R50 is enabled.
However, I did manage to erase the SAS = tire & DSC warning lights on my clock with ease. The warning lights persistently have reappeared from time to time due to a steering angle fault. I've been clearing the faults with my Foxwell before.
Any idea if INPA has the ability to reset the steering angle to 0.00?
NCSexpert loads but the interface is barren. I didn't spend much time with it - until I can find more info/tutorials on how to use it or even if it was installed correctly.
Old Feb 5, 2026 | 07:37 AM
  #32
ssoliman's Avatar
ssoliman
good to hear you got it working. may come in handy some day.
here is what AI says re the SAS. If only it was this easy. ive never done it so i cant say
connect your cable, open the software, and select your chassis (e.g., E46/E90). Navigate to Chassis > Dynamic Stability Control (DSC), press Shift+F4 to open the compensation/calibration routines, and select the F1 option to reset or calibrate the steering angle sensor, ensuring the wheel is centered.
SD200
Oct 15, 2019 01:08 PM
philwarner
Jun 21, 2018 08:03 AM
philwarner
Jun 20, 2018 05:25 AM
Cleve_R53
Aug 16, 2013 07:33 AM
silver-mini-s
Jun 15, 2004 08:34 AM
