R50/53 Advice needed - Need new motor
Old Oct 4, 2021 | 05:05 AM
Mayor's Avatar
Mayor
Hey All;
First time poster. We own a 04 R53 cooper S that we use for a Track Day car. Engine has a ported head and schrick cam, pully etc...
Motor has gone bad (no compression in Cyl 2)
I see lots of stock long blocks for sale but am looking for more of a higher performance engine.
Any recommendations on shops - Especially if they are in the North East, to build a new, strong/pump gas motor?
Any thing to look out for?
A
Old Oct 4, 2021 | 11:28 AM
Nervos's Avatar
Nervos
I'd start with removing the oil pan and head to figure out why it doesn't have compression in #2. Might be something fixable like broken valve or piston (with cylinder walls surviving). And then you will have data to make a decision about next steps - either to look for a new short block, long block, whole engine, or to fix the existing one.
Old Oct 5, 2021 | 05:40 AM
hoodmeister's Avatar
hoodmeister
Where are you seeing lots of stock long blocks? I might need one.
Old Oct 6, 2021 | 01:32 AM
ChiefM's Avatar
ChiefM
AllMag has an engine: https://www.allmagautoparts.com/coll...08-r52-r53-258
Old Oct 6, 2021 | 09:06 PM
mountainhorse's Avatar
mountainhorse
Sneedforspeed has a good reputation and is based on east coast (North Carolina).
https://www.sneed4speed.com/mini-r53-engine-1/
Old Oct 7, 2021 | 05:54 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Since you're in the NE, suggest you check with Eric at HELIX Motorsports in Philadelphia. They've been working on MINI's since the beginning.
Old Oct 7, 2021 | 05:06 PM
Mini_Crazy's Avatar
Mini_Crazy
Here's a bulletproof one. . .
Any recommendations on shops - Especially if they are in the North East, to build a new, strong/pump gas motor?A
Not from the North East, but one longblock has been chosen by a number of successful racers. With its forged Mahle pistons, forged connecting rods, and heavier-duty version of ARP studs it will reliably spin to 8000 RPM and make serious power.
Link: https://store-revolutionmini-com.3dc...ine_p_114.html
It's not cheap, but the price is reasonable, considering what goes into it, and the performance that comes out.
I'm running a RMW stroker (1.8L) torque-monster version of above on the street with occasional track days, and I love it!
Old Oct 8, 2021 | 05:21 PM
mountainhorse
Is Revolution Mini still open ?
Old Oct 9, 2021 | 12:04 PM
jk6672's Avatar
jk6672
Yes, Jan is about done with a 1.8 for me.
Old Oct 26, 2021 | 04:20 PM
mycR55's Avatar
mycR55
Did Jan finish the 1.8 for you? I dropped off my motor for him to rebuild a couple of months ago, but he stop answering emails Oct 1st.
Old Oct 27, 2021 | 06:59 PM
Nicefeet's Avatar
Nicefeet
Originally Posted by ChiefM
Thier report shows 30% leak down in cylinder 2. In my book = ticking time bomb
People still do business with that guy?
Old Oct 27, 2021 | 07:25 PM
mountainhorse
That l
Looking at both compression readings and leak down on that motor don't give me worry though.
Cold leak down.... also depending on precise location of TDC/comp for each reading and what the gauge accuracy is... can cause those kinds of readings.
160PSI cranking compression looks good for me... and on a 125k mile motor...really good.
The 190k motor in one of my R53 has readings in the 30%+ on all cylinders... and 165/160/160/165 compression readings at last weeks plug change.... (cold).
Runs like a TOP.
With that combo... leads me to believe that the valve job is, appropriately, less than new.
Big worries on all these engines are over-rev, bad timing chain/tensioner etc....
I would always put in a new FW/Clutch, Chain/tensioner, and clean the pan/reseal, new F&R seals, all common seals to replace and pop in a new damper... on any W11 car when the motor comes out.... Its the right time for SC service as well
6mins2live
23
Oct 30, 2021 02:44 PM
845
Aug 28, 2014 02:08 PM
brocky
Jan 8, 2014 12:46 PM
Mdunlap R53 Promini
Oct 22, 2013 02:16 PM
ratsauce998
Feb 8, 2012 11:20 PM
