R50/53 Ultra gauge reading negative boost at all times
Old Oct 2, 2021 | 08:20 AM
Mtb Awesome's Avatar
Mtb Awesome
Hi all I just got a ultra gauge for my 2003 mcs and when I looked at the boost pressure it's providing it's was negative at idle which I assume is normal, but when I rev the engine at all it seems to become more negative. Went from -8 psi at idle to around -12 at 4000 rpm. The car does have a 15 percent pulley as well and have done a bunch of work to it. Is the gauge wrong or is something horribly wrong. Thanks
Old Oct 3, 2021 | 05:31 AM
mrbean's Avatar
mrbean
Where on the intake is the gauge connected?
It has to be tapped in "downstream" from the SC.
Old Oct 3, 2021 | 06:58 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
You need to T off the vacuum line on the bottom left corner of intake manifold under the intercooler.
Old Oct 3, 2021 | 08:10 AM
Mtb Awesome
It's a obd gauge so no vacuum lines or anything.
Old Oct 3, 2021 | 11:13 AM
nd-photo.nl's Avatar
nd-photo.nl
If you are able to select the MAP sensor, maybe try the 2nd one.
Old Oct 3, 2021 | 11:18 AM
deepgrey's Avatar
deepgrey
You don't suppose it's pulling data from the MAP sensor instead of the TMAP, do you?
Edit: Ha, nd-photo appears to have beaten me to it.
Old Oct 4, 2021 | 01:57 AM
nd-photo.nl
Great minds think alike :P
Old Oct 4, 2021 | 08:03 AM
Mtb Awesome
It doesn't have the ability to change it but I did notice that when over 3k I do seem to produce 2 - 5psi of boost pretty sure got a major boost leak so wi will try to address that first. Appreciate the input though thank you.
Old Oct 4, 2021 | 08:22 AM
nd-photo.nl
Good luck and report back!
Old Oct 4, 2021 | 08:39 AM
cooper48's Avatar
cooper48
My OBD Fusion Bluetooth app does the same thing until acceleration (15% SC pulley). Then it spins up quickly to 15psi.
Old Oct 9, 2021 | 06:49 PM
Mtb Awesome
Ok so I finally got the new boots and no change. This is going to sound kind of stupid bout could the boost reading coming from a obd port differ from a mechanical gauge. Just because with a 15 percent pulley I don't get more than 11psi at peak boost.
D1QuickSilver
Dec 6, 2021 08:41 AM
sirr6
Electrical
Mar 2, 2016 04:33 PM
MUShadd
May 17, 2009 10:51 AM
chikmagnet
Nov 4, 2005 11:13 AM
Craig_N
Apr 6, 2005 07:50 PM
