R50/53 Antenna base leaking
Old Sep 7, 2021 | 02:54 PM
ninjatuna's Avatar
ninjatuna
Hello, I have a 2005 cooper s with an aftermarket stubby antenna, and the antenna base is leaking. The weather stripping seal is good condition and s flush against the car, however if I lean the antenna backwards it creates a small gap where water leaks through. I removed the portion of the antenna cover box inside the car and was able to tighten the baseplate nut however it did not seem to solve the issue. I will attach pictures below. Do you have any recommendations on how to fix or any other parts I should replacer it with such as a baseplate cover such as the cravenspeed fin. Thank you in advance for any help!
Old Sep 7, 2021 | 03:02 PM
mrbean's Avatar
mrbean
When I had my E46 the "beestinger" antenna leaked. I used some clear silicone caulk from the hardware store to glue and seal the base onto the roof.
I cleaned up the excess really well so you couldn't tell it was even there. Yes, it's a little redneckish, but it worked great.
Old Sep 7, 2021 | 05:33 PM
ninjatuna's Avatar
ninjatuna
Lol, that may be what I resort to.
Old Sep 8, 2021 | 07:39 AM
buzzsaw's Avatar
buzzsaw
Suspecting the antenna base as a source of a leak, I too used a clear caulk purchased at the hardware store and sealed the base. I then took the extra measure and sealed the third brake light and the top of the boot handle as a precaution after reading that those areas may also be the culprits. Sofar so good. Knock on wood. Good luck.
Old Sep 8, 2021 | 03:54 PM
Monkey Juice's Avatar
Monkey Juice
I have the same seeping antenna issue (2005). When I wash the beast , I notice that the interior headliner box...under the antenna is damp...and will occasionally drip a drop onto my rear seat back.
I plan to replace the antenna during the next service.
I have considered caulking ....
Or Penicillin .
Hello to all,
Monkey Juice
Old Sep 11, 2021 | 09:46 AM
Da_Ghost's Avatar
Da_Ghost
Mine was leaking too and I bought a new antenna at the dealer, but the one they gave me is a shark fin and the threads aren't the same as mine and never got around to buying a new nut... body plug has been in the hole for a while now. Some might call it procrastination.
KevinR
Dec 23, 2019 11:39 AM
isedawishy
May 30, 2013 07:58 PM
Americonium
14
Mar 11, 2011 11:14 PM
carla99
Sep 10, 2007 04:02 PM
jbarwilson
11
Sep 8, 2006 11:15 AM
