R50/53 Engine questions
Engine questions
I have a base model R50. I am curious if the 1.6l engine & internals in the R53 are exactly the same (Plus the added Supercharger components), in other words, can I slap the OE supercharger on this engine without stressing it or making internal upgrades? If not, what internals should be upgraded?
Ultimately I'd aim for the JCW upgrade which I understand were add-ons to the R53 set up, so I must know - Do I need an entirely different engine or am I step ahead with this base engine?
Base head and block are the same though.
So you go to the expense of buying a good used JCW engine to put into your R50, then you'll have to buy a used bonnet for the air scoop. You'll have to buy the ECM to go with it, plus the 6 speed trans conversion, with drive shafts (otherwise what's the point). Then will the battery still fit in the R50 location? If not, where are going to put it? And that's just what I can think of off the top of my head.
When I still lived in England, and was into the Mk1 Golf GTI's, I used buy parts and have work done at a tuners called C and R Enterprises in Nottingham (it was close to me). A favorite saying of Steve Cresswell, the "C" in the name, was "Never build what you can buy".
The R53 block is supposed to have a forged crank and rods, lower compression pistons, and oil squirters for piston cooling that the R50 does not have, plus the head difference with the valves as previously mentioned. Not sure if the oil squirters can be added to an R50 block, but even if they can it’s probably a lot easier and cost effective to go with a complete R53 engine or longblock.
Thank you, so a R53/JCW engine harness is added to the list
I'm tired of the midlands trans so a tranny swap is inevitable.
I bought this R50 for $1000 - for the price I am seeing S's in this market (5000 +) , seems a swap will be about on par and give me something to do. For now I am mostly assessing feasibility and donor car prices to keep it a Mini sleeper.
I thank you guys for the info, otherwise I could've gone in blind to some details. Might just swap in a Getrag 5spd & short shifter and be patient for a good donor. Will otherwise focus on suspension and chassis for now. (sleeper since i'd keep it sans any S or fast decals, ill avoid center exhaust, and generally keep it stock R50 outside with 'basic' wheels.
R50/53 R53 S swap to JCW engine
RhinoEngler
Jun 18, 2020 05:36 PM
Drivetrain Engine swap...again: new Dodge 2.0
turbo740
Jul 29, 2005 01:39 AM
