R50/53 Toggle switches
Old Jan 9, 2005 | 11:36 AM
  #26
Sticky Wicket's Avatar
Sticky Wicket
Originally Posted by jonnieoh
QUOTE:
"Yeah, I looked at it. Is that the one that mounts down low on the bumper? If so, it wouldn't work for me because I want 4 lights and the license plate hangs down to low. Unfortunately in NYS your required to have a front plate. Otherwise it would be a great option. I saw a bar that allows for mounting on the grill, but I can't remember where."
Hi Sticky Wicket.
I too, live in NYS, and I've attached the Alta light bar, with only 2 of the 4 lights. Check out my thread to see the results. I've found that the 2 IPF driving/fog light combo lights are wickedly bright. I don't feel I needed another 2 lights...
https://www.northamericanmotoring.co...ad.php?t=34276
I've seen your photos posted before and think its a fairly good look. I just like the asthetic of the four lights across the grill more. Purely a style issue more than one of utility. While some of the roads leading to my house are dark, I'm sure the factory xenons and fog lights would be more than adequate.
Anyone have a bracket or other mounting system they really don't like?
Old Jan 9, 2005 | 12:39 PM
  #27
supergimp's Avatar
supergimp
Regarding switch positions, a friend of mine had his dealer mount his AUX input in the blank switch position on his panel. Easier to reach than the standard glove box position and uniqu application of the blank position.
I ordered the rear fog light for my MCS (Feb build) so I won't have a blank spot. But I though that solution was clever.
Steve
Old Jan 9, 2005 | 04:23 PM
  #28
The_iaiN's Avatar
The_iaiN
Originally Posted by JoeDentist
Two things to remember:
1. The toggle switches are not really toggle switches. They are fake toggle switches that really just press on keyboard type switches on a circuit board mounted behind the switch panel, and that sends data to the computer which actually turns things on and off. They are not like real toggle switches where you can hook a 12 volt line to the back and turn it on and off using the switch.
Okay,I was worried about that. I wonder if there's a kit for the rear fog lights, then I could just route the power to whatever devices i so choose... although that may complicate the wiring... if I'm thinking correctly... how feasible is this? I'd like to have a switch like the one for the front fog lights, with the LED that illuminates when its on... don't mean to hijack this thread, should I start a new one?
Old Jan 9, 2005 | 04:30 PM
  #29
GBMINI's Avatar
GBMINI
There are ways to use the switch & tip ... for example:
http://www.gbmini.net/mtblog/archive/000473.shtml
which links to:
https://www.northamericanmotoring.co...ad.php?t=32593
The main thing to remember is that the switch is VERY low current - it does not control the lights; it only tells the BC1 what to do. If you want to switch some other device you will need a relay or some other current boost system.
Old Jan 16, 2005 | 12:52 PM
  #30
roylevitt's Avatar
roylevitt
Where can you get the garage door toggle from???
Originally Posted by Califzeph
My switches are: Window DSC Lock/Unlock Front Fog Lights (blank) Window
The blank one is used for rear fog lights in states where that is legal.
I hear that you can get a garage door opener circuit to use with one of the empty toggles.
How about toggles to release black smoke, oil slicks and fire missles? The machine gun trigger should be on the blank button on the MFSW!
Old Jan 16, 2005 | 02:31 PM
  #31
GBMINI's Avatar
GBMINI
Don't want to be shouting too loud ... one option is to use the MINI circuit; an optional feature provides an output, controlled by a toggle switch, which can trigger your existing garage opener to transmit ...
Old Mar 31, 2005 | 08:36 PM
  #32
AC_MINI's Avatar
AC_MINI
Originally Posted by GBMINI
Sticky,
Here is a pic of a full panel (click for bigger image):
The most basic panel (MC only) has only three switches - two windows & the door lock/unlock.
The MCS always has the second position - either ASC (standard) or DSC (upgrade).
And you can fill the front and/or rear fog positions if you get the option.
NOTE: You can buy a fully populated switch panel even if you don't have the options - the extra switches won't do anything except look good. My GBMINI had the rear fog switch (toggle switch panel bought from England) at least six months before rear fogs were allowed in USA ...
Where can I get this full switch panel and how much???
Old Mar 31, 2005 | 09:59 PM
  #33
Sticky Wicket
Didn't expect to see this thread resurrected.
Old Mar 31, 2005 | 11:30 PM
  #34
Eric_Rowland's Avatar
Eric_Rowland
AC, you've got two options:
1. The full panel can be purchased from any MINI dealer for ~$75, or from Classic MINI for 20% off that (mention NAM). That is if you want six functional switches (whether you have the options they control is another matter.)
2. Find someone with a few extra toggles who have done #1 above, drill out your current panel and install the new toggles. Search on toggle or toggle replacement for details, and ask again if you have any specific questions.
I'll also plug Ian's auto-up module, 'cause it's so cool. Easy to add once you've removed the toggles (instructions on the site.)http://www.gbmini.net/MINIcircuit/index.shtml
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
