R50/53 R53 Cold start -- sound normal?
I'm new to the R53 world. Does this cold start sound normal? The recording starts at the back of the car and then moves to the front (hood open). Thanks.
https://drive.google.com/file/d/1MzF...ew?usp=sharing
Sounds like your belt tensioner hydraulic damper bushings may be compromised. They crack, fall out and cause the tensioner to rattle against the bolts at either end. Pull your passenger wheel and fender liner and it's right in front of you. You can replace the damper without replacing the belt tensioner. $20 fix if that's the issue.
onequi
Nov 1, 2007 04:38 PM
