oh boy. There’s no way i can even splice the cable from the old seats? There’s gotta be another way
You could remove the occupancy sensor from the old seat and hook it up. Coding is possibly easier though. I bought one of those emulators a long time ago when my sensor failed, but I just ended up coding mine out as well before I could try the emulator. I believe it's OC3 in NCSdummy, but it's been a while.
I just realized that you'd have to code out the airbags as well so probably best to just get everything set up for coding. My brain was only half awake when I answered earlier.
I might be doing a seat swap myself, but just the driver’s side, however I got a buddy that swaps seat in his R56 and they had what he needed, I think he talks to Chad, but don’t quote me on this one.
I had an airbag out of my Countryman briefly. I just disconnected the plug and stuck a 3.3 ohm resistor in the pins. Worked fine?
Note: 3.3 ohm, not 3.3k ohm.
I purchased two MINI wiring "repair kits" for the airbags.
I purchased resistors.
Then soldered the resistor to the two wires coming off that connector.
Then plugged that new connector into the airbag harness for the seat.
When plugged in, the system thinks the airbag is still connected.
YEs, question remains what size Resistor did you use? what years your Mini?
I looked everywhere for the "leftovers" of the airbag repair kit hoping to get you a part no......I think I may have tossed them away cleaning out some old MINI stuff.
Just go to a MINI parts counter and order up a "repair kit" for the airbag side of that harness.
They cost about $50.00 ea I think but works great for a plug and play set up.
awesome man, thank you and what year is your mini?
