R50/53 NGK BKR7EIX Service life?
Those of you who are running NGK BKR7EIX plugs, how often do you replace them? NGK says they should be good for 50,000 miles, but mine have 18,000 miles on them and the car has started having a stumble/misfire occasionally when under load. This was the same symptom that led me to replace my plugs a couple of years ago. I pulled the plugs recently and they don't have anything obviously wrong, but the stumble is definitely happening every now and then. I'm kind of thinking about going back to the NGK BKR7EQU and seeing how long they last.
Check the plugs for arcing, I had a set that I installed and after about 5k miles, I started getting an intermittent miss, I thought "it couldn't be the plugs, I just changed them", chased it for over 6 months, it turned out that one of the plugs had two microcracks in the insulator, and it was arcing down the side of the plug- so check for arc tracks on your plugs.
I will have a look, but I have the MSD screamin demon coil (PO put it on and I've been too lazy to take it off) so I doubt the third terminal is rusty. It's easy to check for sure though. I replaced the plugs today and the stumble is gone so far. One plug (either 2nd or 3rd cylinder) had burn marks(?) some brown discoloration on the insulation above the hex part of the plug. Hopefully this was the problem.
Nik
Ugh, I might, last time I messed with the coil pack I managed to put a hole in the valve cover, hopefully I'm smarter now, but I'm a little scared to touch those bolts.
Also,
be sure to source your plugs from a reputable source and avoid ebay/amazon as there is a problem with counterfeit NGK's which look legit until close inspection.
I was almost burned by fake plugs somewhat recently:
https://www.northamericanmotoring.co...ml#post4546792
Sad but true.
Sad but true.
Also,
Sad but true.
Sad but true.
So I faced my fears and removed the bolts for the coil and replaced it with the OEM coil that came off at about 50k miles. I took it for a spin and it was exactly the same. So for kicks I replaced the magnecor wires with the OEM wires that came off at the same time as the coil. (Thankfully the previous owner included the take offs with the sale of the car)
I took it for a spin with the OEM coil, OEM wires, and new NGK BKR7EQUP plugs and it pulled nice and smooth, no misfire, no stumble. So I'm guessing that the magnecor wires went bad, or maybe I didn't have the wires on good. I'm gonna stick with the setup I have now and see how it does, but hopefully it'll continue to be nice and smooth.
Drivetrain Iridium S. Plugs - How long do they last?
ED955S
Apr 13, 2008 09:46 PM
dominicminicoopers
Nov 7, 2003 09:04 PM
