R50/53 high pitch squeel
high pitch squeel
Bought a cheap 03 R50 that was overheating. Just replaced head gasket, valves, timing chain kit, crank pulley, Idler pulley/tensioner, water pump, radiator, condenser, transmission filter, heater core, serpentine belt, etc. It starts up fine for about 3 seconds then there is a high pitch squeel around the serpentine belt. I haven't filled the A/C system yet. Would that cause the squeel? Any help would be appreciated!
Ok, I did that after I thought about it for a minute! LOL. On my way to NAPA to pick one up now! Thanks for the help! Much appreciated!
Hello everyone, I had the same issue today after driving my car, an '03 R53, about 200 miles with no issues on this belt. It started squealing out of the blue. I am guessing I may have also gotten the wrong belt, as the one I currently have on it is this:
Not called 6pk1033... but then does an R53 have a different belt than an R50?
Multiple people on Amazon say that this belt will work, and I am wondering why the car didn't make the squealing noise for the other 200 miles, what would cause it to just start now?
I have a 17% reduction pulley on the car.
I took the crank pulley off to inspect it, it was fine as far as I could tell. The rubber portion was still whole, not broken in two like often happens.
The tensioner is fine as far as I know, but I don't know if I could tell if it wasn't. What would be the tell that the tensioner is going?
I may try putting on the 532 belt, which is slightly shorter and tighter, and see if that fixes anything. I somewhat doubt it would, as everyone online seems to report that the 535 works fine with a 17%, but it may be worth a shot.
cmayer
Apr 21, 2016 05:03 AM
nshannon29
Oct 7, 2015 05:57 AM
