R50/53 Stock ride height measurement
Anybody have the measurement for the stock ride height for a Cooper S? Ground to bottom of arch? I've got a suspension rebuild in progress and I've got one side higher than the other and I want to make sure I'm working to figure out the correct side. On the stock suspension is the lower control arm basically parallel with the ground when loaded? My current thinking is the high side is gummed up or I forgot to run the strut through a couple compression/rebound cycles before installing it.
Unless I’m missing something, measuring the distance from the center of the hub instead of the ground should eliminate the wheel/tire size difference, but not the sagging springs or plates.
Yep they need to settle most of the time, it it may take like a couple days of driving.
Stripeknight
Jan 11, 2016 12:12 PM
Jackychan
Suspension
50
Jul 17, 2006 02:40 PM
