R50/53 OBDII app
You can use Torgue for basic codes, but there are specific Mini functions that Torgue can't read or reset. I use a Mini/BMW/RR specific scanner, (Schawben). Works well, and you can do lots of troubleshooting,(Testing Components) with it.
Car Scanner Pro is a good OBDII code app. In addition to codes, it allows you to set up gauges like Boost, Acceleration, Fuel Used, Miles Traveled, etc. It also has a neat feature to measure speed over distance, i.e., 0-60mph readings.
I think your gonna need something more than a dongle and an app to do that .
Autel makes the stand alone OBD2 scanners that can also clear SRS codes for MINIs. I installed an amp under the passenger seat of my MINI and when I was testing, I completely forgot about the fact that if you turn the ignition on with the seat out, it sets the light. The dealer wanted $150 to "hook it to their computer", the tool cost me just a little over $125. If you want more details, let me know and I'll look up the specific one I bought but they do work for MINIs and many other brands.
Autel Autolink AL619 Scan Tool with ABS/ SRS Airbag Warning Light OBD2 Scanner, Turn Off Check Engine Light Automotive Diagnostic Tool, Quick Test On The Engine System Scan Tool
it appears the price has come down since I purchased mine.
yes it does. There is a separate section you go into when the unit boots up but it can clear the ABS/SRS light as long as the condition that set the light has been corrected.
Got it thank you... let me order this AL619. This light is really annoying.
Work or not it's fine... I need another scanner anyway.
I am hearing about this ISTA app how hard is this to install\acquire,? I've seen threads that it needs special plugs and adapters.
Armytrix_Exhaust
Mar 8, 2022 06:39 AM
Armytrix_Exhaust
Jul 11, 2019 02:58 PM
TSur
Electrical
18
Oct 11, 2013 06:23 PM
