R50/53 Help with rounded off upper bell housing bolt
Old Feb 10, 2020 | 07:55 AM
frankiev's Avatar
frankiev
Ive been working on replacing my clutch and today I was hoping to remove the last bell housing bolt which is the one thats very hard to get to on the top under a wiring harness . I made the mistake of trying to use a cheap pos Chinese box end wrench and rounded off the bolt a bit . I did some research and found out about rounded bolt removal sockets however most of these are crap chinese junk . I dont want to make it worse so Im looking for suggestions on either a socket set thats good or an alternate method . Any advise is GREATLY appreciated
doing this on jack stands sucks . doing this at 66 with about 2ft of free ground space really really sucks
Old Feb 10, 2020 | 08:50 AM
Black Forest's Avatar
Black Forest
Try a 3/8's 6 point socket, long extension, long handle ratchet and a swivel. It's not the easiest bolt to get but thats how I deal with it.
Old Feb 10, 2020 | 11:51 AM
frankiev's Avatar
frankiev
Appreciate the advice but the problem is the bolt is partially rounded . Seems like all the special bolt removing socket sets skip 15mm for some reason. Bought a special tight fitting set at auto zone . I'll report back tomorrow if they work
Old Feb 10, 2020 | 07:57 PM
aboveliquidice's Avatar
aboveliquidice
Also, make sure you hit it with penetrating oil. It can make a huge difference with 24 hour exposure. Also consider trying heat with the SAE recommendation. Pound it on and use a good socket wrench with a breaker bar. Also consider removing everything out of the way. It makes it way easier to remove the bolt.
Old Feb 10, 2020 | 08:03 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
They have hammer on stripped bolt removers . I've had to use them. They bite into the threads to remove it but you will need a new bolt afterwards as it will only remove not out back on due to how the threads are cut
https://www.ebay.com/itm/10Pcs-High-Bolt-Nut-Remover-Extractor-Set-Damaged-Stripped-Socket-Wrench-w-Case/184087548846?_trkparms=ispr%3D1&hash=item2adc7913a e:m:mIen5wB5EZkitfd0TAW5Zpw
Old Apr 23, 2020 | 10:57 PM
kaxorpie's Avatar
kaxorpie
H
Old Apr 24, 2020 | 07:07 AM
David Baker's Avatar
David Baker
I know that this is a couple of months old but something else to try. If that was the last bolt, put a couple of other easier to access bolts back in and tighten them, not fully torqued but snug. That'll help alleviate any side loading on the stuck fastener and possibly help loosen it.
Old Apr 26, 2020 | 06:47 AM
robj's Avatar
robj
"Sometimes" if the head is rounded off enough, a 6 point SAE socket with go on with a hammer wack or 2. Worked for me in the past. And a big +1 on penetrating oil and patience. BP Blaster is my favorite.
robj
txcowboy
Apr 4, 2019 08:53 PM
mapetitevoiture
Sep 15, 2013 03:52 PM
GreekDrifter91
Suspension
Aug 29, 2013 03:08 PM
weldon978
May 1, 2012 10:15 AM
tominizer
Jun 15, 2010 07:51 AM
