R50/53 I want to upgrade the brakes on my r53
So I have done most of the bolt on power upgrades to my 2006 r53. I have the cold air intake, 15% reduction pulley, craven crank pulley, md ignition, borla exhaust but before I start with the internals I figure I should think about improving my stopping power. I was wondering what people thought was the best upgrade? Brembo or Wildewood or is the r56 brake conversion the way to go? Any thoughts or ideas?
https://www.waymotorworks.com/tsw-mdm-brake-kit.html
Personally I'd go with this kit for the front axle, and go with one of the larger rear discs that utilize the OEM rear calipers to gain some meat. Perhaps we can petition ECS Tuning to release some of their aluminum-hat lightweight rotors for our cars like they have for various VW / Audi applications to get the rear rotor weight to come down with the size increase.
That kit is only $1000 and appears to include everything except for the apparently-required longer wheel bolts (a stud conversion is a smart idea regardless, I use parts that Turner Motorsport used to sell).
pierini1 (06-27-2019)
I have been doing some research on the subject as well.
My first step was more aggressive pads. I went to the Hawk HP+ They squeak a bit for street driving but were noticeably better at higher temps.
R56s calipers, 294mm rotors, SS line and decent pads will set you back about $400-$500
https://www.northamericanmotoring.co...rake-swap.html
After that, it’s a BBK
good info here
https://new.minimania.com/Mini_Coope...lication_Guide
good info here
I did the R56 JCW upgrade https://www.waymotorworks.com/jcw-jo...t-package.html. It's a bit pricey and requires some work to get the rears on but I'm very happy.
WayMotorWorks (07-02-2019)
You should talk to Todd at TCE before you decide. He has a really good perspective on cost vs. what you need vs. wheel size.
Just talked to him yesterday.
https://www.northamericanmotoring.co...ml#post4141578
My advice would be to go with some R56S calipers and 294mm rotors on the front. Leave the rears as-is, they will lock faster than the fronts with stock calipers so you don't need anything fancy there. Stay away from slotted/drilled rotors, they look cool but will crack. Get a good pad compound all-round, which will depend on your the level of brake noise you are comfortable with. The better track-day pads like a Carbotech XP10 will get pretty noisy on the street. For aggressive street the Carbotech AX-8 or Porterfield R4-S are a good choice.
This is roughly the setup I have on my '05 MCS which is raced in 8hr endurance races and the occasional track day. I don't spend more than $30/$15 a piece on front/rear rotors and the R56S calipers cost less than $150 for practically new re-manufacture calipers. I do spend over $400 on a set of pads for front and rear (Raybestos ST-43), but these are race pads that need to last for 8 hours of constant abuse. With this setup (and functioning ABS!) you will be able to out-break just about anything.
I'm not sure why anyone would need huge Brembos or Willwoods on a MINI, unless they are pushing very high HP numbers and racing in short sprint circuit races.
The following 3 users liked this post by angusp:
OK, while I like the video I can tell you fram anything is crap. For full disclosure a video promo of "Pay me now, and pay me later" would better reflect their products.
2005 MCS hatch. I am running R56S front calipers with StopTech low dust pads and drilled, but not slotted, rotors. (They were on sale, so I figured WTH... After 2 years of stop and go Atlanta traffic they are warped now and I will be replacing them with stock solid discs.) The rears are matching R53S parts and have been no problem. I also upgraded to stainless brake lines at the time everything was installed. The stopping power is more than enough for my needs and other than the pulsing from the fronts, I have no complaints.
Late to the party, haven't been on NAM for a bit...sorry.
For a total value purchase the Wilwood factory kits are tough to beat. Pretty much the best of all worlds: differential six pot calipers, aluminum bodies, lighter 2pc rotors, a wide variety of pads, ss hoses.....and fit darn near any wheel MINI has chosen to sell you. All that goodness can be had for under $1100 to the door. (US) If there's a shortcoming it's the thinner pads for those of you looking for hard core race builds. But....that's addressed in the TCE 13" kits with 20mm pads.
Combine that with the 11.75 rear kit and you'll have more brake than you know what to do with! The packaged 4X kits are all inclusive to the door for under $1900. .
Nothing against the R56 stuff here but it's a pure stop-gap purchase you'll outgrow in time only wishing you'd done a real BBK (any brand...) from the start. Don't be that guy.
minsane
Tires, Wheels, & Brakes
12-17-2010 11:26 AM
sgreenie88
04-17-2009 09:11 AM
Xanthus
12
08-24-2003 03:23 PM
