R50/53 What ELSE should I do while replacing clutch?
Old Jun 6, 2019 | 02:25 PM
Jerry Balch's Avatar
Jerry Balch
Hi everyone!
I am going to embark on a clutch replacement, maybe this weekend and am wondering what else you would recommend while she is torn all apart. It is a 2006 R53 with 100k on the clock. I drive it like I stole it, and maintain it as well as possible. Aside from the obvious SC oil change, what else would you all recommend? I have new crank pulley, belt, tensioner, supercharger pulley, and timing chain tensioner (the one on the firewall side of the motor).
I'd love to hear what gaskets and parts I should do while in front end service mode! Or steer me to a thread.
Old Jun 6, 2019 | 02:26 PM
Jerry Balch
Sorry I found several threads, sorry for the questions!
Old Jun 6, 2019 | 02:37 PM
Blue R50's Avatar
Blue R50
I would do the rear main seal and the power steering hoses to the reservoir. I would also get the oil filter adapter gasket as it has to come out to get to the starter (at least on my R50 it does!) . I would also put the car on ramps now, before you are ready to start and give the car a good visual check. Do you have anything that looks bad? Any failing CV axle boots or steering rack boots? Also, get a new O ring for the crank angle sensor as they leak badly and look like a pan gasket leak. Speaking of it, a pan gasket is only like $20 on line, so you might as well get one in case it's needed. Another must do is clean the PS cooling fan. I just did all of it and rebuilt my trans while I was in there ( I also did front struts, bump stops, strut mounts, one motor mount, a ball joint and a 4 wheel brake job too). Count on not having the car to drive for at least a week. Oh, and get a helper to help put the trans back in! It is not flat on the bottom and has no pilot on the input shaft and can be a real pain to do by yourself. BTW, you should also set aside enough cash to buy a new dual mass flywheel if you intend on keeping that system. They run around $500 and cannot be resurfaced if it is badly scarred.
Old Jun 6, 2019 | 05:14 PM
JAB 67's Avatar
JAB 67
Blue R50: I read with interest your response. Are you recommending keeping the OE Dual Mass Flywheel system, rather than converting everything to Valeo? If so, why? I may be in this situation in the near future and can't decide. Thanks.
Old Jun 6, 2019 | 05:26 PM
Jerry Balch
I already have the valeo conversion kit with new single mass flywheel. I think it's honestly more of a preference thing in the end as to which one you do.
Old Jun 6, 2019 | 06:08 PM
mario23's Avatar
mario23
I've also heard the Valeo kit is a great option. It appears to have everything in it. I will likely get it based on my mechanic's advice but curious to hear what others say.
Old Jun 6, 2019 | 06:41 PM
Blue R50's Avatar
Blue R50
I wouldn't keep it, but there are advantages and disadvantages. The dual mass setup is smoother and a little easier on the crank bearings because it can absorb vibrations better. It can also be easier to shift. However, it is also very expensive, heavy, failure prone and can't be resurfaced. Considering the book value of most of these cars, my pragmatism would get rid of it. It is only native to the supercharged models as the R50 never had it installed from the factory.
BTW, Valeo is an OEM supplier to many manufacturers, including MINI. High performance parts are but a small part of their business as a parts manufacturer for multiple OEMs.
Old Jun 6, 2019 | 07:59 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For sure I would do some powerflex control arm bushings since the subframe will be out
https://www.waymotorworks.com/powerf...shing-kit.html
and sway bar bushings
https://www.waymotorworks.com/powerf...-bushings.html
and yes I'd do the rear main seal, guide tube, and fork bushings
https://www.waymotorworks.com/02-06-...-transmission/
Old Jun 7, 2019 | 03:56 AM
JAB 67's Avatar
JAB 67
OE dual mass flywheel $750?? Yikes.
Old Jun 7, 2019 | 05:09 AM
Snaps's Avatar
Snaps
I switched to the Valeo clutch kit last year, and overall have been happy with it. Engagement is overall smoother, and clutch pedal feel is lighter as well. I've heard many folks around here, and on YT who have used them, both for stock, and modified cars, and haven't had many issues. The only asterisk I'd put though is longevity in that my OEM clutch lasted 162k miles before I replaced it. I don't know if the Valeo clutch can last as long as OEM, but time will tell.
One thing that did take a little bit to get used to was the slightly lighter flywheel (also a single mass), which has made rev-matching just a little bit easier, so that was a plus for me.
Old Jun 7, 2019 | 10:32 AM
Jerry Balch
WOW! Thanks everyone for the tips! Looks like I have some parts to round up. Hopefully I can find a decent amount of these locally so I don't have to delay the job.
ACGOG
Nov 6, 2015 01:33 PM
jolson
Feb 17, 2014 05:50 PM
scatpack
Aug 27, 2012 10:33 AM
Carmichael
Apr 7, 2012 10:54 PM
epanarese
Oct 20, 2009 07:14 PM
