Drivetrain Anything else I should do while I install my alta intake?
Old Oct 20, 2009 | 02:33 PM
epanarese's Avatar
epanarese
I'm going to have the airbox completely removed from the car, so does that give me access to any other routine-maintenance points? I remember reading that I can access the shifter linkages. Can I lube them up?
Thanks!
Old Oct 20, 2009 | 03:29 PM
Jonshungry's Avatar
Jonshungry
Hmmm, I don't know. You could check your BPV.
Old Oct 20, 2009 | 03:55 PM
epanarese's Avatar
epanarese
How?
Old Oct 20, 2009 | 04:52 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Wipe down your Throttle body plate, when exposed after reomoving the intake tube....they tend to get gummed up after a while...
If you have a 6spd, lubricate your shift linkage underneith the bottom of the OEM intake box....exposed once your OEM box is removed.
Inspect your vacuum lines, and check your thermostat housing for any signs of seepage
Old Oct 20, 2009 | 07:14 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
check to make sure your thermostat gasket isn't leaking. You have to remove the airbox to install a new one.
AWOL
Mar 28, 2016 10:51 AM
Mib4840
Oct 13, 2015 10:10 AM
stierzy34
Sep 15, 2015 04:40 PM
jrezzo
Aug 9, 2015 10:32 PM
