R50/53 Timing a replacement head.
Old Mar 30, 2019 | 03:38 PM
madtoro's Avatar
madtoro
I have bought a used big valve head, complete with camshaft fitted.
I took off my old head as per manual and lined up the camshaft sprocket using the tool with two pins at TDC on Cylinder 1. (12 O clock)
However, my new head on putting the sprocket on is significantly off (pins are about 2 O clock).
How do I fix this?
Old Mar 31, 2019 | 06:07 AM
Tgriffithjr's Avatar
Tgriffithjr
Did you put everything at TDC before you removed the old head? Are you sure the crank is exactly at TDC? One tooth can make a lot of difference. You say you lined up the cam shaft sprocket but then you say when you put the sprocket on it’s off. Did you put the sprocket on the cam before trying to line up the crank with it?
Old Mar 31, 2019 | 06:34 AM
madtoro's Avatar
madtoro
I think I have figured it out, just over thinking it. It's a used BVH I'm fitting and it came fully assembled, but in a different orientation than the one I took off.
I am going to remove it again and index it until it fits the same tool I used to set the head that I took off, they should then be in the same place / orientation. This should make the marks line up when I refit and put the sprocket back on.
Old Mar 31, 2019 | 08:40 AM
Tgriffithjr
Just make sure both valves on cylinder 1 are closed. It’s possible to have it 180 out. Good luck.
Old Apr 1, 2019 | 10:11 AM
David Baker's Avatar
David Baker
Since you marked your chain and sprocket, just loosen the bolts on the rocker shafts to take the tension off the cam and rotate the cam to the orientation that best matches the chain. Once the chain is on and guides are in, tighten the rocker shafts back down.
Old Apr 1, 2019 | 12:49 PM
Mini invictus's Avatar
Mini invictus
Not my dog, but to clarify. By reducing the tension on cam at the rockers and spinning the sprocket and cam so that they match timing then tightening the rockers you allow the valves and springs to make the adjustment? Is that the thinking?
I am looking at doing a head swap within the year, so I am very interested. Thanks for the clarification.
Old Apr 1, 2019 | 05:40 PM
BlwnAway's Avatar
BlwnAway
Basically, normally the Cam doesn't come tightened down. And since it's a non-interference engine, you simply mark both the chain and the sprocket prior to removal, , do your disassembly taking care to keep tension on the chain and bottom sprocket, (some or one bungee attached to the bonnet usually does the trick except when actually removing and replacing the Head, just make sure to prop the bonnet so it can't accidentally close. I've also zip tied the sprocket to the chain as well) remove the sprocket, remove the Cam, remove the Head. Reinstall the Head, lay the Cam in the saddles, align the sprocket with the chain, spin the Cam until the sprocket lines up with the dowel, then set and tighten you Cam caps and Cam bolt.
Andy Lee
Nov 27, 2018 12:01 AM
kurtsunn
Apr 19, 2018 07:58 PM
CSP
May 15, 2017 11:36 AM
blackprophet
R55 :: Clubman Talk (2008+)
Apr 12, 2016 02:44 PM
jhiggs26
Aug 26, 2013 04:56 PM
