R50/53 Timing chain guides
Old Mar 9, 2019 | 06:29 AM
Acurtis's Avatar
Acurtis
Timing chain guides
I want to change my timing chain guides .can someone point me to a write up on this ? 2005 S
thanks Andrew Curtis
Old Mar 18, 2019 | 05:10 PM
Acurtis's Avatar
Acurtis
Bump
Old Mar 18, 2019 | 05:51 PM
I like mini clubman's's Avatar
Why go to all the work and hassle of doing just the guides? The chain wears out the same as the guides. Get a shop manual and it will show how to do it. Watch a pile of YouTube videos as I did before doing my n14.
Old Mar 18, 2019 | 07:01 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
On an R53 they are pretty easy.
Remove the timing chain tensioner
Support engine, remove pass engine mount bracket
Remove valve cover
remove plugs for guide bolts
lock cam remove cam sprocket
remove guides
do reverse to reassemble.
IN stock
https://www.waymotorworks.com/timing...0-r52-r53.html
Old Mar 19, 2019 | 05:04 AM
cooper48's Avatar
cooper48
You can also check out ModMini on YouTube for repair videos. I'm currently using his videos to swap clutches and he's very thorough, not to mention helpful.
Old Mar 20, 2019 | 05:58 AM
veedubpat's Avatar
veedubpat
This guy's YouTube channel is essentially solely responsible for allowing me to work on this MCS. Just having the full process recorded has been hugely helpful, as these cars are a fair bit more complicated than VWs tend to be (due to the requirement of compactness).
Old Mar 20, 2019 | 11:46 AM
Acurtis's Avatar
Acurtis
My chain is not making any noise .I thought it would be a lot easier to just keep most everything together and put a little tension on the chain to keep it from coming off the bottom sprocket and slip the guides in from the top. If that is not possible ilI' wait till I get some noise. Thanks for the response. A Curtis
Old Mar 20, 2019 | 12:01 PM
Acurtis's Avatar
Acurtis
I do use utube for everything I do to the car. I also have the Bentley book. Thanks Andrew Curtis
Spank
11
Apr 9, 2020 02:23 PM
Brea.doyle
Jul 29, 2018 03:39 PM
silence2-38554
Oct 14, 2015 10:08 AM
Mini Turtle
Nov 14, 2014 06:31 PM
