R50/53 Things to do to 'NEW' engine when swapping '06 MCS engine??
Old Jan 13, 2019 | 05:53 PM
  #26
Tgriffithjr's Avatar
Tgriffithjr
My argument is not whether or not to do the work, but rather if you are going to pull the crank you might as well break it down completely and overhaul it. Why chance putting it back together with the same unmachined crank and cylinders without new rings, etc. let a machine shop check the block and renew it.
Old Jan 13, 2019 | 07:59 PM
  #27
mountainhorse's Avatar
mountainhorse
Good points.
My experience in overhauling motors... if the rod bearings are not 'impaired' the mains will probably be ok... pulling the lower girdle does not intimidate me either... and I may just check it out... if all checks out and plasti-guages well... I see no need to do the mains. This should take very little time... and you make a good argument for tanking the block. I rarely machine a crank on any of the engines I build... unless, of course, it needs it.
Wondering how well balanced these are from the factory in Brazil?
Old Mar 4, 2022 | 10:43 PM
  #28
mountainhorse
Great list of parts...Thank you to Way and all the others that contributed above.
Old May 21, 2022 | 09:01 PM
  #29
mountainhorse
ttt for ya Sam.... post up some pics of your ride when you get it put back together !!
Old May 22, 2022 | 10:54 AM
  #30
mini_me123's Avatar
mini_me123
I didn't pull the engine but this is what I did:
New vlv cover gasket (I regret not doing the spark plug gaskets too now)
new hydraulic tensioner
new belt tensioner
new cooler gasket (triangle) (i'd recommend oil cooler/coolant gaskets while at it)
new crank o-ring (i'd get a dipstick o-ring as well)
new water pump
new water pump gasket
new water pump flange gasket (i'd replace the one on the opposite side/blockoff plate)
new pan gasket
degreased
appliance paint black
mild rebuild on s/c; (at least replace the drive side gasket and fresh oil)
cleaned flashing/casting of s/c
mild ported s/c outlet
port matched charge pipe to s/c inlet
epoxy filled/ported charge pipe
new injectors (at least clean/reflow them)
new passenger's side engine mount
I installed my 15% pulley in vehicle because I was worried about belt alignment. I removed off vehicle.
Check/fix A/c clutch function
check/fix rad fan resistor
Brandon Fluharty
Aug 13, 2021 09:26 AM
Dylan Roberts
Mar 8, 2017 06:35 PM
jeffl
Sep 13, 2016 04:31 AM
jamez
Dec 11, 2014 06:47 AM
KnoxMini
Want to Buy - All Other Items (archive)
Mar 29, 2008 09:26 AM
