R50/53 Brand new Sneed Speed head, horrendous valvetrain noise
Old Sep 25, 2018 | 07:37 PM
Stoney_lowe's Avatar
Stoney_lowe
Brand new head, horrendous valvetrain noise
So I got a new Sneed Speed Street head on my car, install went fine with no real speed bumps. I just started it for the first time and the valve noise is horrendous. Im talking 12valve Cummins on a cold day with no oil bad. Anybody have any insights into why this might be? I put a couple ounces of oil in the top of each piston like i always do on engine rebuilds to lubricate the top end on startup so it shouldn't be an oil starvation issue. I only let it run for about 5 minutes before I shut it down because I'm worried, car runs perfectly and isn't throwing any codes, just sounds like a damn diesel. Kinda wish I would've checked the valve lash before putting it all together but I don't feel like I should have to do that with a part I bought from a reputable speedshop. Anyways, any insight anyone might have would be great, I'm getting to the point where I'm about ready to cut my losses and sell the damn thing.
Thanks, Stoney
edit: my intention here isn’t to drag Sneed Speeds name through the dirt, just wanted the full facts of my situation known to anyone trying to help me
Old Sep 25, 2018 | 10:35 PM
MarioKart's Avatar
MarioKart
Vendor
What year and model is your Mini? Is this a stock head for a ported big valve head?
mQubed Motorsport Manic & RPM Power Tuning
Old Sep 25, 2018 | 10:41 PM
Stoney_lowe
2005 Cooper S, it’s an OEM spec head, the description says it “receives a high flow valve job and valve facing as well as setting the spring pressures for best performance”
Old Sep 26, 2018 | 03:06 AM
ExclusiveWorkshops's Avatar
ExclusiveWorkshops
Have you put the rocker shafts the right way up?
Will do exactly that.
Old Sep 26, 2018 | 11:19 AM
Stoney_lowe
I took pictures and oriented everything exactly as it was sent to me, I’m taking my valve cover off after work today to recheck everything though
Old Sep 26, 2018 | 12:01 PM
ExclusiveWorkshops
I say it because one tech that first installed my Kent cam did this on the exhaust side, he rechecked it three times and said nothing was wrong, others insisted it was the chain but were wrong, I borrowed some new rockers from one of new new heads and fault fixed, I didn't notice on removal as I was just swapping bits and had concluded it was the rockers, so fitted them and the noise went. Ok I thought, just the rockers. Roll on several months I fitted a modified head, on removal of the current one I repatriated the borrowed rockers, and it was then I say the exhaust shaft upside down! Worth a check, it cost 26hp on the rollers ;O)
Old Sep 26, 2018 | 03:40 PM
Stoney_lowe
Ok I’ll check it out thanks for the input, you know if there’s any easy way to see if they’re upside down just with the valve cover off or wil i have to pull the rocker shafts as well?
Old Sep 27, 2018 | 02:12 AM
ExclusiveWorkshops
The bolt head should be on a 'flat' not the curved part of the shaft, you can see with the cover off.
Old Sep 27, 2018 | 10:34 AM
Stoney_lowe
Ok perfect, that’ll help immensely thank you so much
Old Sep 27, 2018 | 07:00 PM
Stoney_lowe
Turns out that was exactly what it was! Upside down rocker shaft on the exhaust side, i feel like an idiot but live and learn eh?
Old Sep 28, 2018 | 05:37 AM
cavaliers60's Avatar
cavaliers60
Now you will always remember what NOT to do.
Old Sep 28, 2018 | 02:48 PM
ExclusiveWorkshops
So glad to have helped, despite the error you must feel relieved so it's all good ;O)
Old Sep 30, 2018 | 05:10 PM
cavaliers60
Just curious if this is the noise you were hearing. Just had my head replaced and now it sounds different. It sounds like what you are describing. Having the mechanic take a look tomorrow.
Old Oct 2, 2018 | 04:44 PM
cavaliers60
Bump? Can anyone confirm the noise? I’d hate to tear this thing apart for nothing
Old Oct 4, 2018 | 05:23 AM
ExclusiveWorkshops
does sound similar, you only need to pull the cover which is easy enough.
Grind
Nov 6, 2010 12:24 PM
plasticknives
Mar 21, 2010 09:35 AM
Fcal124
Feb 15, 2010 06:25 PM
Cadenza
Apr 29, 2009 02:31 PM
jm6001
Dec 13, 2005 08:07 AM
