R50/53 Valvetrain Q
Valvetrain Q
Just curious... do the valvetrains on -06 MCS and -08 MCSc have hydraulic valve-lifters?
I've looked at various photos and didn't see tappets. And does it require valve clearance adjustment if there're no hydraulic valve-lifters?
02 MCS ~ MCSc do have hydraulic lash adjusters.
Reading between the lines, if your hearing lifters tapping, check the oil level.
Last edited by norm03s; Apr 29, 2009 at 01:50 PM. Reason: Corrected terms used in reply to: hydraulic lash adjusters
The singe overhead cam acts directly on the roller rocker arms. The rocker arm end for the valve has a hydraulic lash adjuster in the rocker arm. The #8 is pointing directly at the hydraulic lash adjuster in the rocker arm pictured.
Grind
Nov 6, 2010 12:24 PM
