R50/53 Tires leaning in
Old Aug 8, 2018 | 02:58 AM
Shane O'mac's Avatar
Shane O'mac
Tires leaning in
I just bought a mini. I noticed that the tops of the wheels tilt inward. Does it need alignment or is this just a mini thing? It's a 2006 r53.
Old Aug 8, 2018 | 04:16 AM
cavaliers60's Avatar
cavaliers60
Post a picture if you can.
Old Aug 8, 2018 | 05:06 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Negative camber/leaning in at the top is good to a degree of speaking..
Old Aug 8, 2018 | 06:25 AM
MVPeters's Avatar
MVPeters
Yes, it's 'normal' with a couple of caveats:
The lower control arm bushes, both front & rear, tend to wear, which increases the camber & leads to the inside edge of tires scrubbing.
The rear LCAs are adjustable on later cars - the change point is around 2005/6.
Many owners recommend rotating tires every 5,000 miles.
Old Aug 8, 2018 | 07:00 AM
Whine not Walnuts
A great post
Old Aug 8, 2018 | 09:17 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
You could fit my knowledge of this subject on the head of a pin. However some data might help if I picked the correct info for you.
https://www.newtis.info/tisv2/a/en/r...-guide/6Ilh2L4
Old Aug 8, 2018 | 01:24 PM
Shane O'mac
Here's some pics
Old Aug 8, 2018 | 01:49 PM
HaltCatchFire's Avatar
HaltCatchFire
Here's some pics
That looks just like mine, about normal. Rears are noticeably more camber than fronts with stock suspension.
Old Aug 8, 2018 | 02:37 PM
Fly'n Brick's Avatar
Fly'n Brick
As stated, negative camber is in the design. That looks a little more than mine are but not by much. How many miles on the clock and do you know when and if an alignment job has been done? Rotating has to be done regularly. I do mine every time a 5 or a zero is followed by 3 zeros on the clock. Directional tires rotate same side front to back back to front. Bi-directional for front wheel drive is back to front cross and front to back same side.
SparklingMini
Aug 29, 2008 01:24 PM
meb
Mar 19, 2007 07:25 AM
mbotvinick
Suspension
Mar 16, 2007 04:34 PM
