R50/53 Inside rear view mirror removal
Old Jun 25, 2018 | 10:51 PM
OCR's Avatar
OCR
Ok, maybe a silly question, I know, but I'm installing a slightly smaller mirror onto the windshield like the 70's-90's cars into my 2005, S hatchback/coupe. The stock mirror is too "in my face" and it blocks a lot of the windshield when turning right.
Question is - to unlock the wire harness connector in the mirror body...is this a side to side or a front-back squeeze to unlock it from the mirror base ? I can't pull the wiring far enough out of the head liner to be able to easily see the connector and how it's lock is designed. If I know what direction to "work" things, that'll help get me started.
I don't want to cut the stock mirror wire harness...just because.
Thanks for any help
Mike
Old Jun 26, 2018 | 08:43 AM
Zsm's Avatar
Zsm
You must take off the covers off the mount first. It’s a squeeze of the left and right sides. Separate and then you can get to the harness.
Old Jun 26, 2018 | 11:04 AM
OCR's Avatar
OCR
There's no covers to remove. It's sort of an oval piece that appears to be, one piece. Will look again though.
Thanks.
Mike
Old Jun 27, 2018 | 10:50 AM
RedAggie03's Avatar
RedAggie03
TWIST... comes right off
Old Jun 27, 2018 | 02:07 PM
OCR's Avatar
OCR
RedAggie -
Um...no...reread my question..! I got the mirror removal from the car down pat.
How do I get my fat fingers in to "unplug it" is the question. Hopefully Zsm gave me that info.
MIke
Old Jun 27, 2018 | 05:59 PM
Zsm's Avatar
Zsm
My kid just finished replacing his broken rear view mirror.
I snapped a quick pick of the new mirror. One cover is off and you can see the plug easily.
side cover of rear view mirror removed.
Old Jun 27, 2018 | 10:45 PM
OCR's Avatar
OCR
Yep, got it.
Thanks again Zsm. The seam down the center is very tight/clean, and difficult to see.
Pulled it back down off the roof, and just pulled on the outer housing half's, three pieces and disconnected..!
Got the new mirror in place, MUCH better, now I can see out the windshield without looking around that poorly placed mirror. It's narrower than the OEM mirror, so I need to look side to side a little to see the entire rear window...but that's just fine.
Here's the mirror I used (didn't pay this much..!). It's made of stainless steel. Since the car is silver, I painted the mirror backside dark gray.
https://www.summitracing.com/parts/upd-70802/overview/
I also had to modify the base, the piece that bonds to the glass. Needed to get more angle, got it and all is well.
Right now it's attached with the double sided tape adhesive. We'll see how well it works. It stayed in place thru today's 90+ degree heat.
Now I gotta come up with some sort of cover on the headliner.
Mike
wsalopek
Nov 4, 2020 03:55 PM
modemjunkie
20
Jan 13, 2017 08:27 PM
MINI Jackpot
Nov 2, 2010 08:46 PM
Hypercrew
Factory JCW Talk (2009+)
Feb 12, 2009 10:33 AM
mtbmini
Mar 18, 2004 05:24 PM
