R50/53 Would you buy a '06 with a p2096 code?
Old May 22, 2016 | 01:32 PM
DrewWphoto's Avatar
DrewWphoto
So it seems like we finally found a good replacement for our mini that was totalled last July now that we're on the east coast but it has a p2096 code. The guy said he's replaced the o2 sensor and just hasn't had the chance to get the code cleared.
It has about 80k miles on it. What are your thoughts?
Old May 22, 2016 | 01:42 PM
ZippyNH's Avatar
ZippyNH
What state are you in?
Kinda makes a difference....some let you pass with one item not ready, etc...
I would consider the fact that the o2 sensor might not be the cause...
Often a bad gasket on an exhaust, or cracked header pipe, etc is why there is a code....work it into the price...
Old May 22, 2016 | 02:36 PM
DrewWphoto's Avatar
DrewWphoto
I'm in PA. I'll try and talk him down a bit since that seems like a pain to problem solve.
Old May 22, 2016 | 03:34 PM
Filmy's Avatar
Filmy
Maybe. But a code reader from AutoZone is only around $60, which will also clear codes, and you'd think a seller would do so before making promises on finished repairs. Also, it's good tool to have around.
Old May 22, 2016 | 04:09 PM
ZippyNH's Avatar
ZippyNH
A cheap code reader WILL NOT CLEAR a hard emissions code....
That's the hard part...it needs a pro level tool...or this..
Originally Posted by David.R53 View Post
I've bought from this guy. Still, be careful - I installed it on a junker Win7 laptop I don't use for anything important. Comes with the software and cable. The seller even helped with install problems. Start reading about how to use inpa and dis. This is the dealer software that can do everything ... Even program new keys if you have the patience to learn how.
BMW USB OBD Diagnostic Cable Inpa Ediabas Ncsexpert Dis V57 SSS V32 Progman GT1 | eBay
The 2096 can be a hard one to track down...so price it in.
Old May 22, 2016 | 04:30 PM
DrewWphoto's Avatar
DrewWphoto
Yea I think I'll just pass on this one
Old May 22, 2016 | 05:26 PM
ti22fjc's Avatar
ti22fjc
I've had a P2096 since installing exhaust. I'm sure it's a leak somewhere but haven't had a chance to really track down. I'm really use to driving it with that light on.
If it works for you, I'd talk him down. You may still fall under an O2 warranty and the dealer may take care of it.
Old May 22, 2016 | 05:29 PM
DrewWphoto's Avatar
DrewWphoto
The car has an Alta exhaust installed so I don't think the warranty would replace it.
Old May 22, 2016 | 05:48 PM
ZippyNH's Avatar
ZippyNH
A 2096 typically is caused by a leak BEFORE THE CAT....it forms a tiny venturi (the lack of a seal, in the form of a failed gasket, cracked pipe, or bad flex joint), and can suck unburnt air in...the o2 sensor then can see unburnt oxygen, and reports a lean condition.
Sure...sometimes a cheap aftermarket o2 sensor can cause it...but it's a different issue in most cases.
quickcoop
Dec 4, 2020 09:05 AM
IQRaceworks
Nov 29, 2018 07:36 AM
TankedMini
Mar 23, 2016 04:18 AM
spikeyadrian
Mar 18, 2016 07:24 AM
GAT
Mar 11, 2016 11:08 AM
