R50/53 High/Rough Idle
Old Apr 18, 2016 | 02:38 PM
cagersguy55's Avatar
cagersguy55
High/Rough Idle
Hey guys,
Just got done installing my new 17% pulley and a few other things, and I noticed that my car was idling very fast (1500-1800 RPM) even when warm. I also noticed that when I would give the throttle a little tap to get it to settle down, it would drop to about 1k, get rough, then go back up. I've had about 3 rough starts since the install also.
Any ideas?
Old Apr 19, 2016 | 07:28 AM
IQRaceworks's Avatar
IQRaceworks
Sounds like you may have a vacuum leak somewhere......
Old Apr 19, 2016 | 10:13 AM
cagersguy55
Is there any common locations to check for this? This may be congruent with what I saw when I had O'Reillys scan my SES, it was the idle air control (for high RPM), but my MAP reading was low (10 mmHg)
Old Apr 19, 2016 | 10:42 AM
IQRaceworks
There are some vacuum lines on the passenger side of the motor....right where you were at when you swapped the pulley. Check for any cracks in the tubing, or plastic fittings.
Old Apr 19, 2016 | 10:54 AM
cagersguy55
Everything looks good on those, that was my first thought when you said vacuum leak. The lines, connectors, and nipples on the valve look good.
Old Apr 19, 2016 | 01:32 PM
cagersguy55
Got it, everything is now running good! Thanks for the help
Old Apr 19, 2016 | 02:27 PM
gsfent's Avatar
gsfent
Might be helpful to someone else if you share what you found......
Regards,
Jerry
Old Apr 19, 2016 | 02:56 PM
cagersguy55
Regards,
Jerry
It was the Grey MAP (?) line that goes to the front bottom of the supercharger (right in the middle basically). But now it is doing it again so I have no clue what it is. It didn't do it the whole drive after, had CEL cleared, went out for a drive and the light was back on and I had a weird idle. About 1.2k RPM but it was fluctuating all over the place
noladude70001
Apr 19, 2016 02:07 PM
Apr 17, 2016 05:27 PM
R58 :: Coupé Talk (2012+)
Apr 17, 2016 05:01 PM
Apr 17, 2016 04:43 PM
Apr 17, 2016 04:37 PM
