R50/53 Some unusual electrical symptoms
So, I've been running into some issues with starting on cold mornings—the voltage drop from cranking is enough to turn off all the cabin and dash lights. Ordinarily, I would have thought 'well, time for a new battery', but I borrowed a battery tester from Autozone, and at the battery, the voltages are fine both sitting there and under load—certainly not bad enough to turn everything off.
Possibly related: when I start the car in cold weather, the speedometer rattles around 0, making a buzzing noise, before settling down once the car has started.
I might have guessed ground straps, but that should have shown up during load testing on the battery, right? The terminals at the battery side are in basically perfect shape, and the battery is only as old as my ownership of the car, so two and a half years or so.
What was the voltage that the battery reader said? Any codes present in the system? The buzzing has been said to indicate a bad battery. Check out this NAM thread HERE where the issue turned out being a bad positive terminal cable.
888.280.7799 | 6am - 5pm PST
I tested at the battery in the trunk, though. If I test between the positive terminal under the hood and ground, that should show different voltages from the battery if the cable is bad, right?
A normal battery should read a voltage above 12 volts with the car sitting still, and no electrical devices on. (Don't worry about the door lights, they hardly make a dent). A typical reading would be in the 12.6-volt range when the battery is fully charged. If the reading is 12 volts or less, then the battery needs charging or needs to be replaced with a new one. I have seen instances where individuals reported a bad battery at 12.2 volts. Most of what I have seen points to signs of a battery going bad. Some have pointed out that it's a quirk as well. Some more info HERE.
Great, glad i could help.
six82
Dec 15, 2015 04:32 PM
