R50/53 Can someone throw me a bone?
I've tried numerous techniques over the past week to program my keyless remote to work, but I'm having no luck. I've even opened up the remote to confirm the hardwired battery is installed and charged. At this point I'm thinking it's the BCM or IR receiver. Is the IR receiver in the rearview mirror in the '07 R52 MCS? What's the usual suspect, BCM or IR receiver if the car won't take programming?
EDIT: Just realized I posted in the wrong area. I'll ask a mod to move.
You didn't mention what year car & key fob you're using. If you aren't aware of it, you cannot program '04 and earlier keys - that's only for '05 & up. If you do have an older car and key, you would have to visit the dealer and pay them an hour's labor to program it.
I have an '07 R52 MCS. I only have one key, and the keyless function hasn't worked since I bought the car a few weeks ago.
Is there a possibility that the key that came with the car is one of those worthless E-bay keys? The only key that will work with your car is a factory provided key set to your VIN. To get one of those you HAVE to contact a dealer, provide a copy of your title and DL (copies can be faxed or emailed) and it has to be picked up at the service desk. There's a simple get acquainted procedure you have to do with it in the ignition which the service guy will explain to you.
I'm starting to suspect the BCM was replaced with a used unit, which would then disable the keyless entry function.
I've attempted the "get acquainted" technique at least 30 times using around 4 variants I've found on YouTube or Google.
I'm pretty certain it's the real deal. It has typical wear and tear and when I broke it apart it had the same composition as the OEM's. Plus it has the hardwired battery, which isn't replaceable.
I'm starting to suspect the BCM was replaced with a used unit, which would then make the keyless entry option null and void.
It's possible the receiver isn't working, and it's the easiest thing to investigate further. Unfortunately that receiver isn't available separately (only included with a complete mirror assembly). Also see if it makes any difference if you hold the key next to the mirror while attempting to program. Does the lock switch in the toggle bank work properly? BTW, it is a radio receiver, not IR (infrared).
I am doubtful that the BCM had been replaced with a used unit. That's difficult to accomplish without other obvious issues cropping up.
If that were the case, it wouldn't start the car.
10-4, I'll try to test it and investigate repairing if its not emitting a signal. I think I recall seeing something at an autoparts place that could determine if a keyfob battery was low/dead.
I just went to O'Reilly Auto and had the keyfob tested. It isn't working. I guess I'll be replacing the microswitch. Thanks for the info Andrew.
Instead of soldering a new microswitch in, can I swap my laser cut key and chip into a used key off ebay? Is that doable?
The eBay key is just a blank. It wouldn't come with internals. Even if it did you would still need the dealer to program it, correct me if I'm wrong? I don't believe you can just swap chips?
This thread covers the relevant concepts: https://www.northamericanmotoring.co...for-cheap.html
I would transfer the original immobilizer chip into the eBay circuit board and put that into the original shell.
zakindi
Dec 16, 2015 11:45 AM
Codypantz
Dec 14, 2015 01:07 PM
1QukMINI
Dec 14, 2015 08:59 AM
