R50/53 2005 R53 Daytime Running Lights Ceased Working
Hey, does anyone have any idea how to fix my daytime running lights. Just installed new H-7 bulbs after noticing both of my DRL's weren't working. I have Zenons for the nighttime lights. The fusible links are ok. Is there a relay I'm missing? At a loss because the regular lights work and the high beams (H-&'7) are working fine. HELP!!!
DRLs on R50/R53 are dimmed high beam headlights. It is a programmable option that can be enabled by a dealer or shop using software such as NCS Expert.
+1 , yea they are very dim high beams
They are in the bottom of the light housing below the Xenons.
It is funny. Fuses are ok. I've checked every fuse that has lights associated with it. I've had DRL since I bought it new in '05. Not sure when they stopped working, I thought that both bulbs had burnt out.
Like I said, I've had these since it was new. So perplexing.
Good point. I think i may have an old bulb around where I've replaced both, but one bulb was still OK to use as a check. I replaced these with PIAA H7 Ion Yellow bulbs. i'm assuming these would work as DRL's.
did you verify a bulb issue? PIAA not waking up????
if not
car wasn't software reflashed for a service issue anywhere along the way was it?
If so, maybe they lost the DRL programming ..... it is something that can be turned on off
if not
DRL turned off at one time maybe when there was a computer flash update by the dealer ?
Not The Bulb
Thanks everyone! As soon as I can I'll get to the dealer and have them take a look and let you know.
Thanks for the update , yep looks like it was turned off.
silence2-38554
Dec 4, 2019 06:14 PM
WayMotorWorks
Dec 11, 2015 10:06 AM
WayMotorWorks
Dec 11, 2015 10:04 AM
escriba
Dec 10, 2015 12:39 PM
ad78
Dec 9, 2015 11:41 AM
