R50/53 DIY fuel ring tool?
Old Nov 19, 2015 | 06:16 PM
schr5530's Avatar
schr5530
DIY fuel ring tool?
Chances are I'm replacing my fuel pump and filter soon. I don't like the idea of using a hammer and chisel to remove and instal the retaining ring but the BMW tool looks to be around $80 and I'll probably never use it again.
Any one try making a tool? I would think if I could get the right size pipe and notch it?
Old Nov 19, 2015 | 06:56 PM
Wertles's Avatar
Wertles
Honestly using a hammer and regular screwdriver, it came right off in about two whacks. The same to put it on. No damage at all to anything. Save yourself the $80 and put for something actually useful.
Old Nov 19, 2015 | 07:29 PM
IQRaceworks's Avatar
IQRaceworks
It's not worth it to buy a special tool. A hammer and a screw drive is about as easy at it gets. A few taps and the ring comes right off
Old Nov 19, 2015 | 08:14 PM
Rich.Wolfson's Avatar
Rich.Wolfson
I agree. Really no need for that tool. Buy a belt tool if you don't have it already. That you will need someday.
///Rich
Old Nov 19, 2015 | 08:15 PM
Filmy's Avatar
Filmy
Use a <i>brass</i> drift (like a chisel) just to be safe. Brass won't spark when you strike it, or when it strikes other things like steel retainer rings.
Old Nov 23, 2015 | 06:04 PM
MazMini's Avatar
MazMini
I changed my filter the other day and used a flat head and a hammer...
Old Nov 24, 2015 | 07:55 AM
Most use a flat head and a hammer to lightly tap it out.
https://www.northamericanmotoring.co...er-change.html
DIY:
https://www.northamericanmotoring.co...hange-mcs.html
Old Nov 24, 2015 | 08:54 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1. Once the line is disconnected, use the hammer and screwdriver to carefully tap the metal locking ring counterclockwise until you can unscrew it by hand and lift it up and off the filter housing. We have a DIY that goes over all of these steps that may be of use to you for this project.
888.280.7799 | 6am - 5pm PST
Old Nov 25, 2015 | 12:30 AM
wellzy's Avatar
wellzy
Why not get a upgraded fuel pump from greene performance like i did?
3 year no fault warranty!
Rocket_man
Feb 6, 2016 02:40 PM
Alpha Motoring
Jan 17, 2016 03:26 PM
sempdog
Nov 6, 2015 09:56 AM
AvianMan
Nov 3, 2015 11:00 AM
Smthkd
24
Oct 29, 2015 10:04 PM
