Fuel Pump Problem
Old Oct 31, 2015 | 10:39 AM
sempdog's Avatar
sempdog
Fuel Pump Problem
If someone could provide some insight it would be greatly appreciated.
Fuel pump:
The problem is that there is no power on the fuel pump relay pin 30. The fuel pump relay trigger (pin 86) has 12v when the key is on, so that part is working. I need to find out if the alarm system or an impact fuel cut sensor is disrupting the power supply to pin 30 on the fuel pump relay.
Old Oct 31, 2015 | 10:41 AM
sempdog's Avatar
sempdog
Last night my buddy and I connected 12v to pin 87 on the relay, the fuel pump started, therefore we know the fuel pump is good
Old Nov 1, 2015 | 04:02 PM
Ronnie's Avatar
Ronnie
Check to see if you are getting fuel at the schrader valve. I had a fuel pump problem too. my car would not crank/start.
Follow the link how to check the valve @ Pelican technical: http://www.pelicanparts.com/techarti...mall/pic03.jpg
Old Nov 5, 2015 | 06:54 AM
Did you figure out what it was yet ? Did you get full up front on the line / pipe before the injectors.
Old Nov 6, 2015 | 09:56 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1
http://www.pelicanparts.com/techarti...eplacement.htm
888.280.7799 | 6am - 5pm PST
Aug 30, 2017 05:10 AM
Jan 14, 2016 11:42 AM
mdaz75
Oct 29, 2015 04:21 PM
Suspension Products
Oct 28, 2015 10:32 AM
JPMontes3
Oct 26, 2015 02:02 PM
