R50/53 Crankshaft Seal Brand Recommendation
I bought a Valeo clutch and based on numerous recommendations I am planning on replacing the rear main seal while I have it apart.
Does anyone have any brand recommendations? Stick with OEM at $40? Are any of the other brands worth buying? Fel-Pro is $10 on Amazon.
I realize that with the money I spent on the clutch and the time it's going to take me $20 or $ $30 isn't that much, but I hate spending money I don't have to.
go oem, it's only a few dollars more
$18.95 vs $26
http://www.waymotorworks.com/search....=search&page=1
When I did mine I didn't have one ordered in time so went with fel-pro from my local parts store. The first one didn't fit! Thought it was me and tried for about 10 minutes to get it in. The second one looked completely different (same part number) and fit great. It took about 10 second to push in. It doesn't leak oil and I'm not really worried about it but next time I do a big job I'll wait for the oem parts.
$18.95 vs $26
No issue here with the VR or genuine MINI one. This is the larger one near the transmission side. 11111492244
https://www.ecstuning.com/Search/SiteSearch/11111492244/
11111492244 seal Genuine or Victor Reinz have good reviews at that link. I'd stick to those options.
888.280.7799 | 6am - 5pm PST
Welcome.
I'm replacing my clutch as well, and I am inclined to replace the rear main seal as a precaution. There's not one write-up anywhere on the forum, and the Bentley manual calls for some obscure MINI special tools that are a one-time use item. What is an alternative method of replacing the new seal without the use of those special tools? Soft punch and mallet?
Pry the old one out with a screw driver.
I use the old seal on top of the new one to tap it in. Soft hammer works fine too. Absolutely no special tools needed.
I wouldn't use a punch though, you might put a hole in it.
Also most of the local part stores stock the seal in case you screw it up,.
I recently did my clutch and used the Fel-Pro seal and an oil pan gasket. Have used lots of Fel-Pro products through the years w/ small block Mopars w/ no problems. Tapped the seal in carefully and slowly w/ a small rubber mallet. If you check out ModMinis videos on YouTube you can see it done. Easy, just take your time.
Cool another mopar guy, I mostly dealt with 440 stuff though. I think everyone of mine, and all my friends big blocks still leaked oil even after new seals were put in lol.
Fel pro is fine, I just happened to get one that didn't fit.
Oct 13, 2015 03:12 PM
greentrees
Oct 12, 2015 02:19 PM
