R50/53 I give up!
Old Nov 2, 2015 | 02:42 PM
  #26
Kahnfucious's Avatar
Kahnfucious
Originally Posted by Smthkd
No I have a bolt extension going down the center of the puller and pulley.
Sorry - did I just read that you screwed the bolt through the puller? Assuming that was a typo. Sequence goes 1 - bottom out the longer bolt 2 - attach puller (arms) to the pulley 3 - thread pointed bolt that came with puller into the puller and against the longer bolt 4 - turn slowly until you are getting some pressure 5 - gently tap the puller bolt a few times 6 - keep wrenching on the puller bolt - gonna need some torque - but don't go full gorilla 7 - once it starts moving keep turning the bolt Take it all off
Old Nov 2, 2015 | 02:53 PM
  #27
Smthkd's Avatar
Smthkd
No, I have followed the instructions from Pelican. I no longer have a viable way to attach the puller due to a broken tap in one screw point and a stripped second point. My three claw puller dosent fit. The claws are too thick. I have tried everything and still no luck.
Old Nov 2, 2015 | 03:18 PM
  #28
SPRINTCARS's Avatar
SPRINTCARS
How much to thick? Can you trim the puller down and or open up the hole in the balanced ? A new balancer might be on your list anyway unfortunately
Old Nov 2, 2015 | 04:38 PM
  #29
AoxoMoxoA's Avatar
AoxoMoxoA
I think you're at the point where you either have to adapt (by grinding) a pulley puller to custom fit your application, or succumb to bringing in a professional to do the job and be done with it. You may find when this is all said and done that some nitwit used red loctite to permanently affix the pulley to the shaft.
Old Nov 2, 2015 | 04:52 PM
  #30
bavmotors's Avatar
bavmotors
Originally Posted by bavmotors
I had to slightly modify the jaws by grinding them to get them to grab well enough. It's by no means easy, but that's how you will get it off.
did you read this post?!? You will need to grind the puller claws down in order to get a decent grab. It's not going to be easy.
silence2-38554
Nov 5, 2015 06:48 PM
Colt45Magnus
Nov 3, 2015 04:34 PM
gpzjack
Nov 3, 2015 03:24 PM
Smthkd
27
Oct 29, 2015 06:52 AM
SteveZ
Oct 28, 2015 08:28 PM
