R50/53 part number request
Old Oct 17, 2015 | 10:11 AM
zxtuner's Avatar
zxtuner
part number request
I need the the connector part numbers for the power steering pump. mine have fused together after lost power steering on the way home from work and by the time I got home everything was too far gone.
If anyone has any suggestions on what to do or if you have fixed this problem before I am all ears. I am stuck right now and I am not sure how to get my car back on the road. taking it to the dealer is not an option at this point. I am in a northern suburb the are on the south side of the city.
I am in the twin cities if that helps. I am scouring craigslist for parts cars right now as well.
Old Oct 17, 2015 | 10:48 AM
David.R53's Avatar
David.R53
There are places that will rebuild the power steering pumps for around $200. I used ModuleMaster for $225. It helps If you post your year, model and build date.
Old Oct 17, 2015 | 11:11 AM
zxtuner's Avatar
zxtuner
I have a new pump on hand my issue is the connectors going to the pump are melted together so I need part numbers or someway to get connectors with pig tails that I can splice in and attach to the new pump.
Sorry I should have been more clear about my issue in the first post.
Old Oct 17, 2015 | 11:20 AM
Nicefeet's Avatar
Nicefeet
I think the part number is 61132359998, but I'd call Motorworks MINI to verify
Old Oct 17, 2015 | 11:28 AM
zxtuner's Avatar
zxtuner
Thank you Nicefeet, would you happen to have the other connector number as well? I may need both. :(
EDIT: I just searched and ECS carries it. I am currently searching for the other connector on Pelican Parts and ECS
Thank you again I am very grateful for that part #!
Old Oct 17, 2015 | 12:11 PM
David.R53's Avatar
David.R53
This is the part diagram for an 03/03 build date - you can change that to yours to confirm the part numbers are correct
http://www.realoem.com/bmw/enUS/show...diagId=32_1265
Part number 11 and 12 are the "signal" connector and "power" connector. The contacts that fit into the connector are sold seperately and are listed below the connector.
Old Oct 17, 2015 | 01:39 PM
zxtuner's Avatar
zxtuner
Hey David and Nicefeet thank you both for your help! Both of you have given me new site for part numbers and the info I was looking for.
Old Oct 17, 2015 | 01:52 PM
David.R53's Avatar
David.R53
You're welcome. Hope you get it fixed.
Old Oct 19, 2015 | 09:13 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you ever need help with a part number on our site please do not hesitate to reach out to me on here!
888.280.7799 | 6am - 5pm PST
Old Oct 19, 2015 | 02:21 PM
EDIT: I just searched and ECS carries it. I am currently searching for the other connector on ECS
https://www.ecstuning.com/Search/SiteSearch/61132359998/ES2844512/
& 61130005199 x 2
https://www.ecstuning.com/Search/Sit...199/ES2676087/
We have the full kit right here, MINI now has full repair kits, used to be the socket and the plugs separated. Let me know if you need anything else.
#12 12521439891 plug
https://www.ecstuning.com/Search/SiteSearch/12521439891/
#12 female wire 12520144161
https://www.ecstuning.com/Search/SiteSearch/12520144161/ES2672658/
Old Nov 30, 2015 | 08:02 PM
zxtuner's Avatar
zxtuner
I need some more help with this now, I picked up a whole high power wiring side. I can't recall where the ring terminal goes. I've tried searching images here and google and other sites and I just can't seem to find where that goes. any help provided would be awesome.
Thanks,
Jon
Old Dec 1, 2015 | 06:10 AM
ring terminal, do you have pics of this ?
Old Dec 2, 2015 | 05:05 AM
zxtuner's Avatar
zxtuner
I will see if I can't get some tonight
Old Dec 2, 2015 | 05:33 AM
ok, thanks
Old Dec 2, 2015 | 07:38 AM
David.R53's Avatar
David.R53
Hey ECS Tuning - BMW also sells pins already crimped onto wire "pigtails". I'm assuming the electrical connectors are shared with BMW...
It would make this kit much easier for people without the fancy tool to crimp the metal pin onto a wire. Think you can track down those part numbers and add them to your kit?
Old Dec 3, 2015 | 05:43 AM
They are added above for both plugs. Encase people want them.
Old Dec 3, 2015 | 05:51 PM
Minston's Avatar
Minston
You may have figured this out but my favorite is realoem.com, find your part # and google it, works every time!
NorthWestEuro
Oct 22, 2016 07:57 AM
martinb
Oct 7, 2015 05:00 PM
micromini234
Sep 30, 2015 07:36 PM
olson187
Sep 30, 2015 07:12 PM
Norton70
Sep 22, 2015 01:36 PM
