R50/53 2nd head gasket under 75k?
2nd valve cover gasket under 75k?
I'm looking at a used 05 with 75k on it. It's a nicely equipt mcs and seems decent overall for low 7s. Should I be leary? I'm getting it from a broker but he says the owner is adult 55plus. New clutch also around 60k miles. Thoughts?
Several head gasket changes: I'd be concerned. Valve cover gasket changes: nothing to worry about. I guess some of them start to weep at some time; mine hasn't. My '05 has 114k on it now; never had VC or head removed. I am going to do the cam soon, so the gaskets will all be changed at that time.
Usually the bolts are not tighten because they are corroded on the head of the bolt.
The gasket is not too bad, its those old rusted bolts that can be a pain if the heads are rusted.
Hardware linked:
https://www.northamericanmotoring.co...er-screws.html
Valve cover gasket set here: 11121485838
http://www.ecstuning.com/Search/SiteSearch/11121485838/
Hardware linked:
COOPT UP
Sep 11, 2015 04:59 AM
Sep 2, 2015 09:05 AM
