R50/53 Power steering fan
This should be the current Part Number 32416857718
...here are some of the Superseded Part Numbers:
32416781742 (05/21/2007 — 03/08/2012),
32416777632 (07/19/2006 — 07/25/2007),
32416774702 (09/01/2005 — 05/29/2006),
32416768827 (03/14/2004 — 01/12/2006),
32414026606 (10/08/2003 — 07/01/2004),
32416761038 (03/01/2002 — 12/29/2003),
32416760126 (11/01/2001 — 02/18/2002)
No matter which of the part numbers you order you should get the current Part Number.
Motor on!
Motor on!
Can reference the part number here.
Our parts catalog is pretty helpful when searching for the correct part number for things so if you need any other future help be sure to check it out here!
-Luccia
-Luccia
888.280.7799 | 6am - 5pm PST
Here the power steering parts number for the full fan and bracket.
We also have just the fan listed if the bracket is ok and not rusted to pieces and the fan with the bracket now come with the new fan grille. Which on older MINIs they did not have the grille. They both come with the under in line resistor.
P/S Pump Cooling Fan W/ Grille Part # 32416857718
https://www.northamericanmotoring.co...fan-issue.html
Great, let us know of it goes on the install.
Are these REALLY needed?
And not, 'MINI had them on their so they must be - you're going to DIE if you take it off!!!' - or, 'it's $130, it's cheap insurance'.
I just bought one and even with my big skidplate a single rallycross had the thing all crunchy. I was thinking maybe mounting it up top and drilling a hole through the hood to draw air up around the back of the motor...until I read someone had thrown theirs in the trash years ago and been totally fine.
Anyone else have real life (not theoretical) data on this?
Thanks a lot guys!
Pat
Thanks a lot guys!
Pat
It cools the pump, which I don't think I would test overheating the P/S pump when they are expensive and some work to replace. Also runs with the A/C.
You can get just the fan itself linked above, just make sure the old one has the grille to block plastic bags and such. Heard stories of plastic bags getting stuck in there with no grille.
Which skid-plate are you running ?
I have the Rennline skidplate:
http://www.rennline.com/Aluminum-Ski...oductinfo/U01/
Good protection but even less airflow...
Rennline is good and does block it a little bit but protects the fan and under body. It still gets air.
Your up north, but sometimes it gets hot. I would get the fan replaced with the fan only unit, if you want. If the p/s pump overheats or something , that would not be good.
What year are you , MINI extended the warranty for the P/S pump and fan for certain years.
My car is an '05 - paid out of pocket to have the pump replaced back in '07 - got my reimbursement check from MINI a couple years ago. What a nice surprise, they even paid for my state inspection that was on the same bill!
Great just wanted to let you know.
Manny_cooper
Sep 10, 2015 11:09 AM
Aug 25, 2015 09:33 AM
minipopkart
Aug 13, 2015 05:22 AM
