R50/53 Redrum
Old Jun 2, 2015 | 06:39 PM
batrugger's Avatar
batrugger
Redrum
After more than two years sitting, we just finished up an RMW engine install. Redrum is back.
Old Jun 2, 2015 | 07:22 PM
Stinch's Avatar
Stinch
WOW, that is a great looking MINI!
Old Jun 3, 2015 | 04:39 AM
JABowders's Avatar
JABowders
Veteran: Army
Great looking car...
Motor on!
Old Jun 3, 2015 | 05:08 AM
Nice. The Factory Aero on Chili red, Im in love.
Old Jun 3, 2015 | 05:27 AM
Helix13mini's Avatar
Helix13mini
There has to be a story about the hub caps: front S logo, rear 50s brassiere. Do tell...
Old Jun 3, 2015 | 05:30 AM
Yea, the story is this MINI looks awesome. Congrats on up and running.
Old Jun 3, 2015 | 12:27 PM
batrugger's Avatar
batrugger
Thanks everyone. The story is that Schmidt makes some seriously great wheels and some really crappy plastic center caps that break easily, and we like both styles lol.
Old Jun 3, 2015 | 11:56 PM
Chris Hall's Avatar
Chris Hall
I just want that hood scoop, where can I get one???
Stellar MINI sir!!
Old Jun 4, 2015 | 10:40 PM
batrugger's Avatar
batrugger
Thanks, the hood scoop is an infamous Palo Uber scoop from 06 and is no longer made. It was much hated at the time, but we sure get a lot of compliments on it now lol.
Old Jun 5, 2015 | 06:23 PM
cdemarco4's Avatar
cdemarco4
Stellar MINI sir!!
It is available at m7tuning.com
Old Jun 5, 2015 | 09:49 PM
batrugger's Avatar
batrugger
Just checked there. M7 does not sell Palo Uber scoops. Their Vortex scoops are not the same.
Old Jun 6, 2015 | 06:20 AM
gmonde's Avatar
gmonde
how about some details on the engine build,, I have one on the engine stand that will be gone thru ,,looking for some feed back on different approaches ,,gmonde
Old Jun 6, 2015 | 09:08 AM
batrugger's Avatar
batrugger
Engine by Revolution MINI Works Bored to 77.5mm at 8.5:1 Capable of 350+ whp
RMW Custom Pistons
RMW Custom Rods with 3/8" ARP2000 Rod Bolts
Mahle F1 Style Rod Bearings
RMW Custom Oil Pan Baffle
New main bearings, oil pump, chain, chain tensioner, chain guides, rear main seal, head gasket, ARP head studs, and all gaskets.
SFI FluidGel Vibration Damper Crank Pulley
RMW Big Valve head with:
Black Nitrided 1.8mm Oversized Intake Valves
2.3mm Oversized Inconal Exhaust Valves
Supertech Valvetrain with Titanium Retainers and Beehive Springs
ARP Head Studs
RMW Custom Camshaft
We already had the RMW head and cam and it was all refreshed
Old Jun 6, 2015 | 11:59 AM
BernieCoop's Avatar
BernieCoop
Gorgeous Mini. Looks great and those engine specs are impressive! Nice work!
Old Jun 6, 2015 | 06:33 PM
gmonde's Avatar
gmonde
do you think if the compression was 9:1 it could live on 93 octane?,, I am saying for guys who daily drive and most of driving is not under boost to get better throttle response and when you hammer down for a short run it doesn't rattle the valves out of the head ,, did you dyno the engine ??
Old Jun 6, 2015 | 06:42 PM
Mikal68's Avatar
Mikal68
Bad ***
Old Jun 6, 2015 | 07:28 PM
batrugger's Avatar
batrugger
Don't know, I left that up to Jan at RMW. I know the head is good though, it is the same configuration that they use on the race cars. No dyno or tune yet since it is still in the break in period, but it made 267 whp before with the stock block.
Old Jun 7, 2015 | 05:04 PM
gmonde's Avatar
gmonde
just curious ,, if you keep your foot out of it what kind of fuel mileage do you get ?
Old Jun 7, 2015 | 07:04 PM
damncajun's Avatar
damncajun
Did you know Redrum backwards is Murder? You probably didn't. Racecar backwards is Racecar. Your mind is blown I know.
Old Jun 7, 2015 | 08:05 PM
batrugger's Avatar
batrugger
Can't really say. It has to be driven 300 more miles surging to 4500 rpms and then letting drop down to 3000 rpm and then back again. It isn't getting good mileage like this
Old Jun 8, 2015 | 06:28 AM
In Socal the MINIs stay so clean.
Old Jun 8, 2015 | 06:37 AM
Helix13mini
If I'm not mistaken, you are the one with the really cool home. Am I correct? If so, show the crowd a shot of your MINI and house--It's worth a look. If I'm smoking crack, ignore this post.
Old Jun 8, 2015 | 09:18 AM
batrugger's Avatar
batrugger
I don't know if your smoking crack or not lol, but here is an old photo from when it was in MC2:
Old Jun 8, 2015 | 09:35 AM
Helix13mini
^Well just a little, only in the mornings--ya know, to calm the nerves.
Old Jul 17, 2015 | 04:28 PM
batrugger's Avatar
batrugger
The car has been running great, but there were a few hiccups. After we did the first oil change we loaded it up and drove 200 miles to Vegas to go to Wuste and AMVIV and it ran awesome the whole way there other than the AC dying after running for about 15 secs. Nothing like a 400 mile road trip through the desert in June with no AC. We drove to the show and shine at AMVIV on Saturday from the Palace Station where Wuste was and when we got there it started running rough. After AMVIV we got it back and parked it at the Wuste show and it sat until Monday. I couldn't figure out the problem and there were no codes, but we needed our 200 mile break-in oil change so we took it to Kensington motors. He did not want to put 10w-40 Rotella in lol, but I insisted and they did the oil change, found a hole on the bottom of our GP intercooler which was causing a vacuum leak, and they said our AC compressor was dead. Couldn't fix the intercooler or the AC so we went ahead and hit the road. Once it got going on the freeway it was running great and we made it home without any issues except that it finally tripped a code for the pre-cat O2 sensor.
Since I was in an automotive course at the college, I took it into class on Wednesday with a stock intercooler to check out the sensors. I swapped it with a spare and it still ran badly. Hooked it up to a scanner and while it was idling it got really bad and the header started glowing red hot.It then tripped 4 codes for the O2 sensor heaters, cam sensor, and EGR. I shut it down and did some research and found thet the F03 fuse under the hood had popped and that it controlled all of those. Replaced the fuse and it popped again. I unplugged all of those sensors, replaced the fuse, and started plugging everything back in. It popped when I plugged in the pre-cat O2 sensor wire. Since we have the race header, there is an extension cable for the O2 sensors. I pulled the extension off, replaced the fuse, plugged the sensor in and the fuse didn't pop, problem solved. The vacuum leak caused the exhaust to run too hot and it slowly melted the extension cable first making it run roughly and then finally fusing all 4 wires together which popped the fuse.
Luckily I was able to fix the AC with a new clutch coil and I got the intercooler repaired at a local radiator shop. I installed a new extension for the O2 sensor and then fired it up. It sounded better, but still not right and since it was almost dark I noticed the header was glowing. I determined that my boost gauge was leaking so I disconnected it and plugged the line. It ran better and no glowing exhaust, but still seemed rough. The injector pigtails had insulation that had pulled away that I had taped up so I went ahead and ordered new pigtails. After installing those it has been doing great. We've almost got it to the 500 miles point after the last oil change which will be the next oil change for break-in. Big thanks to Jan and Colin for answering my texts and calls and helping me get it sorted. Here's a quick vid of how it sounds right now:
