R50/53 R50 sans rear spoiler w/ holes plugged.
Old Mar 24, 2015 | 12:07 PM
FatherG's Avatar
FatherG
I pulled the spoiler off a few days ago and plugged the holes with 5/8" plugs (1" top) I picked up at the hardware store.
I was not aware that the holes would be oval - not circular - so to keep the plugs from sliding I put a bit of silicone waterproof painter's caulk on the underside of the plug caps to hold them in place and seal the surfaces. This will do until I decide to have the holes properly sealed and painted.
Still needs a bit of clean-up...
Attached Thumbnails R50 sans rear spoiler w/ holes plugged.-spoiler.jpg
Old Mar 24, 2015 | 12:18 PM
Mib4840's Avatar
Mib4840
Are you aware that MINI actually makes some little aero dynamic "fins" that cover these holes? I know ECS and a couple other vendors carry them. I just replaced my wing and have a set ready to paint to cover the holes.
Old Mar 24, 2015 | 12:34 PM
FatherG's Avatar
FatherG
Thanks. Yes, I've seen them, but I prefer the smooth surface - that is why I am going to likely weld and then grind the holes.
Old Mar 25, 2015 | 03:43 PM
ItzNeil's Avatar
ItzNeil
Each to his own...
Funny that I spent $100 to ADD a wing where there was none...
Old Mar 25, 2015 | 07:23 PM
Mib4840's Avatar
Mib4840
But it was worth it, wasn't it?
Old Mar 25, 2015 | 07:25 PM
Mib4840's Avatar
Mib4840
You've got more guts than I do! I would rather do the hole fill too, just don't have the talent and don't want to pay what the body shop would charge.
Old Mar 25, 2015 | 08:02 PM
FatherG's Avatar
FatherG
I should have said: I'm going to pay someone to fill and grind the surface. I can do the paint work myself however. If the cost seems too high (I'm a cheapskate), I may teach myself how to fill the holes properly with a filler and do all the work myself.
Old Mar 25, 2015 | 08:54 PM
ItzNeil's Avatar
ItzNeil
Shouldn't be hard to fill since you access both sides, if you weld, you'll have more rust protection to do where its harder to reach.
Old Mar 25, 2015 | 08:57 PM
ItzNeil's Avatar
ItzNeil
And MIB, yep, worth every penny. ��
wkp1219
Nov 13, 2015 07:52 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Mini'mon
Aug 26, 2015 01:02 PM
ludedude
Aug 10, 2015 07:16 PM
