R50/53 No chrome tail lights
Old Feb 16, 2015 | 09:22 PM
808keith's Avatar
808keith
I finally got around to tackling this.
Sorry admins I think this should've been in mods thread.
Old Feb 17, 2015 | 05:28 AM
Saltysalt's Avatar
Saltysalt
cool beans! split them open and painted?
Old Feb 17, 2015 | 05:29 AM
Looks clean , nice job. Doing this to the Euro OEM taillights would look great also.
Euro Taillights
https://www.northamericanmotoring.co...il-lights.html
Old Feb 17, 2015 | 10:30 AM
808keith's Avatar
808keith
yup split them apart but the chrome just rubbed off with rubbing alcohol
Old Feb 17, 2015 | 11:39 AM
808keith's Avatar
808keith
Euro Taillights
Those euro tail lights look pretty cool.. might have to see about getting some of those later on down the line..
Old Feb 17, 2015 | 11:45 AM
Very cool.
Those are the pre 7/2004 . not a direct swap for the 7/2004+ models , will have to do so wiring mod due to no reverse light.
Old Feb 17, 2015 | 12:23 PM
dw1's Avatar
dw1
@808Keith: Can you post a little more on the process, I assume you removed the taillights then split them? Are they pretty easy to split?
BTW: great looking Mini and light treatment. Nice work.
Old Feb 17, 2015 | 01:28 PM
808keith's Avatar
808keith
You'll see where the clear lens meets the black plastic body the sealer/adhesive they used. That's where you'll be cutting through. I used a dremel with cut-off wheels but maybe should've tried one of those little saw blade attachments as the cutoff wheels kinda melt it as you go. Just carefully go all the way around and the lens will come right off.
Inside the red lens will pop out but you gotta be a little careful as it's held in with 4 tabs. Use like wide flathead scewdriver or maybe like a stiff putty knife to help pry it out. It sounds like it breaks but that's just it releasing from the clips. Once it's out, I used rubbing alcohol to wipe off the chrome paint.
When putting everything back together it's jus the reverse.. pop in the red lens and make sure everything is clean.
On mine one of the lens I used 5-min JB weld and the other I used black silicone adhesive. Just wanted to see which was better.. So far both seem to work ok no difference except working times.. the JB is quick setting unless you use the regular JB weld and wait till everything has cured over night.
Sorry I didn't take any pics.. with a 1 year old I had a limited window in which to get this project done..
Old Feb 17, 2015 | 05:10 PM
'10JCW's Avatar
'10JCW
Sorry to derail the thread, but I miss living in Hawaii so much......
Old Feb 17, 2015 | 05:55 PM
808R53's Avatar
808R53
Cost of living here has sky rocketed.
Old Feb 17, 2015 | 05:58 PM
808keith's Avatar
808keith
Some more pics
Attached Thumbnails No chrome tail lights-image-4033985451.jpg   No chrome tail lights-image-876414908.jpg   No chrome tail lights-image-3220026049.jpg   No chrome tail lights-image-2173233522.jpg   No chrome tail lights-image-3984662192.jpg
Old Feb 17, 2015 | 06:05 PM
'10JCW's Avatar
'10JCW
Yea we moved in 2012
Old Feb 17, 2015 | 07:39 PM
808R53's Avatar
808R53
Living in paradise is costly.
Old Feb 18, 2015 | 05:31 AM
Saltysalt's Avatar
Saltysalt
its a place I wanna live haha, island of maui entices me
Sexual Chocolate
Mar 31, 2019 08:02 PM
Mb460
Aug 20, 2016 10:39 PM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
