R50/53 Aftermarket Shift Knob Options?
Old Dec 27, 2014 | 01:13 PM
KIBCO's Avatar
KIBCO
Aftermarket Shift **** Options?
So i have been looking through NAM and the interwebs and i seems that the only Mini Specific aftermarket **** is from Whalen Shift Machine. Are they any others. i am only interested in a **** made for the mini cooper not a universal or one that requires an adapter. if it makes a difference i have an 02 R50
Old Dec 27, 2014 | 01:23 PM
bavmotors's Avatar
bavmotors
What kind of ****? I have a carbon fiber ball ****, got it off amazon for $25 it's identical to the m7 minus the logo. It does use allens but no adapters.
Old Dec 27, 2014 | 01:26 PM
KIBCO's Avatar
KIBCO
i was looking at the M7 one but i wasn't sure how secure the allen screw would be.
Old Dec 27, 2014 | 01:48 PM
bavmotors's Avatar
bavmotors
They hold really well, even if your one of those fast and furious shifters.
Old Dec 27, 2014 | 01:50 PM
KIBCO's Avatar
KIBCO
BAHAHAHAHA i guess ill keep that in mind
Old Dec 27, 2014 | 06:42 PM
Zillon's Avatar
Zillon
Raceseng.
I've got one installed on my R56 and love it.
Old Dec 27, 2014 | 06:49 PM
KIBCO's Avatar
KIBCO
havent heard of receseng ill look into it thanks. that red looks good with the stitching.
Old Dec 27, 2014 | 07:11 PM
GEMSTER's Avatar
GEMSTER
Check out Whalen Shift Machine. Lots of NAMers use it. I love mine.
Old Dec 27, 2014 | 07:13 PM
KIBCO's Avatar
KIBCO
yeah Whalen is the only one i have found made for the mini. i was just seeing if there were any other options out there.
Old Dec 27, 2014 | 07:29 PM
Zillon's Avatar
Zillon
They recently released their R50/R53 and R56 fitments - for more info, check out my review, HERE.
Old Dec 27, 2014 | 07:40 PM
KIBCO's Avatar
KIBCO
sweet review im leaning towards that ashiko 735G!!!!!
Old Dec 30, 2014 | 05:00 AM
IQRaceworks's Avatar
IQRaceworks
Yep, I found a nice one off of Amazon also...around $25. I can't see spending $80+ on a shifter ****...that's nuts.
Old Dec 30, 2014 | 05:24 AM
minsanity's Avatar
minsanity
No point changing ***** unless going for heavier 1s. That 735gm ashiko by raceseng will be sweet.
Old Dec 30, 2014 | 05:28 AM
cristo's Avatar
cristo
Alliance Member
Raceseng has some nice ***** - including some delrin-wrapped ones about
1# in weight like their Topologi - for those who don't want to grab a metal
**** in the dead of winter or the heat of summer. Pricey like the Whalens,
but they look appealing.
http://www.raceseng.com/topologi-shi...6-speed-manual
http://www.raceseng.com/auto/mini/shift-*****
Old Dec 30, 2014 | 06:31 AM
minsanity's Avatar
minsanity
Very appealing indeed!
Old Dec 30, 2014 | 10:30 AM
Zillon's Avatar
Zillon
I've been very pleased with the 600+ gram Slammer.
The Ashiko would truly be one bad *** ****.
Old Dec 30, 2014 | 01:12 PM
KIBCO's Avatar
KIBCO
yeah im definitely going with the ashiko unless i find something heavier. id rather spend $150 and change shift feel then spend $25 and make it pretty. luckily that ashiko will be both
Old Dec 30, 2014 | 04:59 PM
minsanity's Avatar
minsanity
+1. The heavier the better.
Old Jan 2, 2015 | 10:19 AM
IQRaceworks
Why?
Old Jan 2, 2015 | 10:48 AM
cristo's Avatar
cristo
Alliance Member
A heavier shift **** gives more momentum/inertia when shifting, which helps on the
relatively high-effort nature of the Getrag and its associated shifting mechanism,
especially when engaging reverse.
... up to a point. If you attach a 16# bowling ball, it's gonna make it worse, not better.
I would guess that about 16-24 oz (1 - 1.5# or 455 - 682g) - would be the sweet spot
in terms of weight range for a shift ****.
Old Jan 2, 2015 | 12:31 PM
IQRaceworks
That might hold true if you are slamming through the gears in a race car, but on a daily driver...I doubt anyone would ever notice. Not much inertia force generated with slow easy shifts.
Old Jan 2, 2015 | 02:58 PM
cristo's Avatar
cristo
Alliance Member
Go ahead and put on a full weight bowling ball, then!!
If it's too heavy, use a 12 lb. ball like women often use.
Let me know how it goes.
Old Jan 2, 2015 | 03:28 PM
nkfry's Avatar
nkfry
The Whalen **** is a fantastic piece, from the weight to the custom engraving, everything about the **** is great, but the price is steep.
I have a Craven Speed **** on my car, which they have as of recent stopped manufacturing due to cost. It weighs a little less than the Whalen ****, but is also half the cost.
We have one left in stock, $99 plus shipping.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 2, 2015 | 03:47 PM
Zillon's Avatar
Zillon
I beg to differ.
Old Jan 2, 2015 | 05:01 PM
IQRaceworks
Let's say it takes you 1/2 second to make a shift.....moving your shifter **** 4 inches. That means you are moving your shifter ball 8 inches per second.
If the shifter **** weights 16oz (1lb or .4535kg)..and it's moving at 8in/sec....that's equal to .2032 meters/second.
When you do the math...the momentum change is 0.09 kg-m/s. So.. that means that .09kg (3.17oz) of force for every meter per second.....so .2032.
So...3.17oz x .2032 = .64 ounces........that is how much extra momentum a 16oz shifter **** generates when you move it 4 inches in 1/2 a second. That's .04 lbs. What's a stock know weight? 1/4lb? OK...so you changed the momentum by .01lbs ....that's nothing.
I'm not 100% sure the math is right...but I think it's pretty close
