R50/53 Wire plug in on Manuel transmission?
Old Oct 7, 2014 | 06:28 PM
Brchopper's Avatar
Brchopper
I have a 2003 r53 that I put a new clutch in.all went well except I have no back up light and my bulb is good. On my transmission there is a two wire female end socket. I am thinking the socket leads to a switch in the transmission that turns my reverse light on, but I'm not sure. I can not find a wire anywhere on my mini to plug into this socket. Does anyone know if the socket on the transmission is for the reverse light ? Also , if so, where does the wire originate from that plugs into the socket? Thanks for the help.
Old Oct 7, 2014 | 08:13 PM
MiniR53's Avatar
MiniR53
Yup, there is a switch that connects to the trans to turn on the reverse light. Check out this thread, might be useful for you.
https://www.northamericanmotoring.co...ml#post2709748
Old Oct 8, 2014 | 08:07 AM
ForcedFed4's Avatar
ForcedFed4
Its on the back side of the transmission under where your airbox should be. I did the same thing when I did my clutch. Its pretty difficult to see where it goes but that's definitely the problem you have.
Old Oct 8, 2014 | 06:52 PM
Brchopper's Avatar
Brchopper
Can't find the wire
Thanks for the help. My problem now is I can't find the wire to plug into the transmission. I have followed every wire I can find and no wire is not plugged into something. I am hoping someone can tell me where the transmission wire originates so I have an idea where to start looking. Thanks.
Old Oct 9, 2014 | 06:37 AM
Here you go.
https://www.northamericanmotoring.co...on-06-mcs.html
The wire might be hanging out somewhere under the airbox disconnected.
Old Oct 10, 2014 | 02:57 AM
Brchopper's Avatar
Brchopper
Still can't find the wire
Spent an hour with a flashlight and mirror following wires without finding one to plug into the tranny. Running a k&n so I don't have the airbox in the way. Pulled off the front wheel and jacked up the car. Feel like I've looked everywhere. The cars new to me but stock so I got to think when I dropped the tranny I must of unhooked the wire.
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
Super Coop
Aug 17, 2015 05:09 PM
Getrieben
Aug 15, 2015 09:09 PM
