R50/53 R53 ECU interaction with suspension?
Old Mar 21, 2014 | 08:18 AM
tmscaf's Avatar
tmscaf
I took my mini in for a badly needed alignment. When I got it back I found out that my mini was both a manual alignment and a computer alignment to get everything into range. Can someone shed more light on the specifics of how that system works? I believe that the ECU governs the potency of the power steering based on the speed you're going, but I'm unsure on if the ECU does anything with the suspension. Just curious about it.
Old Mar 21, 2014 | 08:23 AM
ZippyNH's Avatar
ZippyNH
Ecu is JUST engine management......think you misunderstood....
When they said they did a computer AND a manual alignment was how the WORKER did it.....
Old Mar 21, 2014 | 08:24 AM
daonlyillwiz's Avatar
daonlyillwiz
+1
Old Mar 21, 2014 | 08:37 AM
tmscaf's Avatar
tmscaf
Gotcha, I appreciate the clarification on that. It probably didn't help that I wasn't the one picking up the car so I wasn't able to ask the technician these questions =p
Old Mar 21, 2014 | 08:38 AM
jamez's Avatar
jamez
...and the fact that R53 has hydraulic steering - not controlled by a computer.
As mentioned above, I think you misunderstood that it the operator used his computer and manual equipment to get everything aligned. Either that or they're just talking through their buts
Good to see everything's taken car of now though.
Old Mar 21, 2014 | 08:41 AM
tmscaf's Avatar
tmscaf
LOL, well I appreciate the further clarification on the power steering as well! And yes, the alignment, new tires, and new front end bushings made a night and day difference. Feels like a new car!
Old Mar 21, 2014 | 08:51 AM
daonlyillwiz
makes sense...
Old Mar 21, 2014 | 09:01 AM
tmscaf's Avatar
tmscaf
I was thinking because the power steering pump is electric, it could control the actual voltage/amps to it which would regulate the efficiency of it. I actually didn't second guess that part when he mentioned it. The suspension though I didn't think had anyway of being controlled by the ECU.
iggi
18
Feb 9, 2026 01:00 AM
twistedimages
Sep 19, 2024 04:13 AM
Finhead
105
Aug 14, 2023 07:51 AM
Emnotek
Aug 13, 2015 05:47 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
