R50/53 Removal of Warning Sticker on Visor
Old Feb 15, 2006 | 04:16 PM
  #51
COOP310's Avatar
COOP310
I removed my warning stickers with denatured alcohol from home depot while the visors were still in the car.
You will get the best results if you use a white cotton towel instead of cotton ***** or paper towels. Some have suggested allowing a towel saturated with the denatured alcohol to sit on the visors for a minute or two before attempting to wipe them off - this seems to work pretty well. Be sure to clean the visors after the sticker is removed using a mild soap and water mixture and another cotton towel, to avoid discoloration.
Old Feb 16, 2006 | 05:21 PM
  #52
DixieHill's Avatar
DixieHill
Yesterday, on the way home from work, I stopped and got denatured alcohol from Home Depot. Drank two beers trying to get the nerve up to remove the visor stickers and then decided I better wait until I was stone sober. Got the nerve up to remove them tonight and followed COOP310's advice on the cotton towel. After letting the soaked towel sit on the stickers about 1.5 minutes (impatience got the better of me) I was able to remove the stickers by just wiping with pressure. There is some 'ghosting' where the stickers were and I'll probably go buy some Goof Off tomorrow to try to take care of that.
Very easy mod and I would do it again.
Thanks for all the posted info!
Old Feb 16, 2006 | 08:07 PM
  #53
BoCRon's Avatar
BoCRon
Of course, this is just another opportunity for more graphics!
Here's mine.
Annette
Old Feb 23, 2006 | 09:05 AM
  #54
garretwp's Avatar
garretwp
Hey guys I just removed the stickers from my visors! Another thing you can do is use a heat gun! It works wonders and the sticker will peel right off when heated! After that, just use some solvent to remove the glue and you all set!
Garrett
Old Feb 23, 2006 | 10:29 AM
  #55
bamatt's Avatar
bamatt
Here's mine.
Annette
I think the visor decals look great but was a bit shocked when I found out the cost for 2 small stickers so I think when I have some time to kill I will be trying the denatured alcohol/removal route
Old Feb 24, 2006 | 06:36 AM
  #56
WingNut's Avatar
WingNut
Originally Posted by chrisneal
Does peanut butter work?
Only if you get the sticker caught in your hair.
Actually I never though to do this... I'll have to go have a look at these stickers...
Old Mar 15, 2006 | 12:01 PM
  #57
sagworks's Avatar
sagworks
running with scissors
Well, instead of removing mine, I also covered it up. Here are my made at home visor stickers. I am sure they will fade within a week or two. It is my trial run before getting a more professional (and permanent) set made.
Old Mar 15, 2006 | 12:10 PM
  #58
roddw's Avatar
roddw
Here's mine.
Annette
nice look! where did you get your stickers?
Old Mar 15, 2006 | 12:20 PM
  #59
-Jonathan-'s Avatar
-Jonathan-
Garrett
I assume a hair dryer will work? Maybe run it for 20 minutes until it slips off like ice?
Old Mar 15, 2006 | 03:16 PM
  #60
Herby74's Avatar
Herby74
Annette.....that's exactly how I too got rid of the visor warning stickers. It's a very clever and decorative solution. Recently, I also ordered a mixed pair of topper decals (Union Jack & Stars 'n Stripes) for my new '06 MCS.
These decals are from Mini Pirate. They're a British outfit so shipping is expensive and orders take a bit of time to get across the pond.....but they have some neat ideas.
Old Mar 15, 2006 | 07:31 PM
  #61
Snappychip's Avatar
Snappychip
I tried Goof-off with no success... but I'm impatient so I may not have waited long enough... I'm going to try either Goof-off again or denatured alchol and see what happens.
Old Mar 15, 2006 | 08:45 PM
  #62
WEEGIT's Avatar
WEEGIT
Denatured alcohol works fine if you let it set long enough - several minutes. The Goof-off (Goop-off really) is only to clean up the gummy residue, which should be almost non existent if the alcohol is left alone. Be patient.
Old Mar 17, 2006 | 11:53 PM
  #63
FUNMNI's Avatar
FUNMNI
I just did it! Thanks for all the info. I used regular rubbing alcohol, 70% and soaked a paper towel and layed it directly on the sticker, I have a convertible so I flipped the visors and with the top down was able to work from the top, not having to remove the visors...anyhow, after about 2 - 3 minutes, I was able to use start from the corner of the "sticker" and roll it off. If there were left over pieces, I used the soaked paper towel to rub it off. Afterwards, there was a bit of adhesive mark/residue so I rubbed it once over with the alcohol soaked paper towel. To be extra sure, I put goo-gone directly on the area, be careful not to spill, I had towels on my seats just in case it would drip. Anyhow, after about 1 - 2 minutes, I rubbed it off and then for the final touch, I used Mother's Back to Black and voila! Done. It took about 30 minutes, the longest part was rubbing the sticker off. Cool! Thanks again!
Old Sep 20, 2014 | 01:56 PM
  #64
davidtobin's Avatar
davidtobin
Best way to remove visor label
This is BY FAR the easiest way to remove the warning labels on your visor. Pick up some ACETONE from the hardware store and put some on a rag and just rub the sticker off. 3 minutes per visor.
Old Sep 20, 2014 | 04:44 PM
  #65
dosomething's Avatar
dosomething
AGREE
Old Sep 21, 2014 | 09:23 AM
  #66
Cary Cooper's Avatar
Cary Cooper
Originally Posted by CooperBeagle
Curious if new MINI owners are still removing these. I was in a new
BMW 325xi this week and saw the warning sticker again.
I remember when I initially came to NAM, (MCO), it was the first thing
I learned from the site, and I was so excited to use the information to
clean up the interior clutter. I bought the denatured alcohol, soaked
some paper towel and held it to the stickers, and they rubbed right off
just like I was told they would.
...ah memories of when my MCS was new!
Godspeed.
_________________
Just make sure you replace it with this one (select the image it will be larger/legible)
I saw it at this website: http://www.stuckonminis.com/Stuck_On..._Stickers.html
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
cawwwtun
May 3, 2016 08:03 AM
greekzilla
Aug 23, 2015 03:44 PM
JamJam43087
Aug 16, 2015 02:02 PM
