R50/53 Tire rubbing issue/fender roll????
Old Nov 1, 2013 | 12:10 AM
Spencershakes's Avatar
Spencershakes
I have an 05 MCS and I just got 17"x8.25" offset is 25. I knew it would be a tight fit and it surewas... Rubbed right when I got them on, only the rear though. And all the way home. I trimmed up the fender and rolled the inner metal liner into a flat crease. Not to hard, I don't rub while driving, only on turns and dips. Unfortunately I am beginning to rub down the portion of the fender with the light/reflector in the rear. Is there anything I can do to push out the fender just a bit more? Anyone experienced this before?? Or with fender rolling at all?? Any feedback at all would be great. Thanks!
Old Nov 1, 2013 | 06:42 AM
STF_U's Avatar
STF_U
What size tire do you have on that wheel?
Old Nov 1, 2013 | 07:18 AM
yetti96's Avatar
yetti96
BFH or persuasion, but it may not end up pretty.
Old Nov 1, 2013 | 09:09 AM
ZippyNH's Avatar
ZippyNH
Since you have plastic edges on your fenders....
I would not try it...
You can bend the metal....but the plastic will no longer snap on or fit...beckinda ugly IMO.
Old Nov 1, 2013 | 10:44 AM
Spencershakes
My tire size is a 215/45/17. I was wondering if I went with a 205/45/17 if it wouldn't rub as much.
Old Nov 1, 2013 | 10:45 AM
Spencershakes
Old Nov 1, 2013 | 11:50 AM
AlexQS's Avatar
AlexQS
That would make it narrower, by half of the difference between the aspect ratio and. -Nevermind, LOL. (.....it confuses me to even think about this.)
Here's a link to a calculator that will make it easy to compute.
http://www.rimsntires.com/specs.jsp
Edit,.. BTW, when I say narrower, we're only talking about a little bit. Guessing around 3 or maybe 6mm
Old Nov 5, 2013 | 12:44 PM
drewffff's Avatar
drewffff
I've got 215.45.18 (not 17) on my 2005 S and the rear rubbed a tiny bit, so I put spacers between the rear spring coils. It worked and didn't seem to effect handling.
Old Nov 5, 2013 | 03:15 PM
Spencershakes
Right, but what is your offset? Are you on factory wheels? My offset is really really aggressive... its 25, so my wheels stick out quite a bit. Im rubbing just behind the outside of the fender. If i were to put spacers it would be bad. haha
Old Nov 5, 2013 | 04:13 PM
GreekDrifter91's Avatar
GreekDrifter91
hmm are you lowered at all? is it just one side of the rear? I am running 215/45/17 too and the driver side rear rub very very little and the passenger rear rubs a lot just over bumps and big dips in the road. it too has rubbed through the same spot in yours right at the reflector. I wonder if tightening up the bumper and liners would make it stop. my bumpers and stuff sag a lot.
Old Nov 5, 2013 | 04:23 PM
Spencershakes
Yeah, i have lowering springs. Im looking into some coilovers so i could possibly raise it up a couple cm then make the springs stiffer. Hopefully that will help, are you lowered? and yeah, its strange, my left rear tire sticks out a little more than the right. Its never been in an accident, im thinking maybe they dropped the sub frame a little off center or something like that.. its weird. let me know if you do anything and it helps the rubbing!
Old Nov 5, 2013 | 06:19 PM
GreekDrifter91
yea im on koni yellows and swift springs, i need to investiate the actual area which i havent done yet. i just put on my "winter" setup so i know i wont rub so sorry to say i prob wont check it out till the spring time lol.
Waszak
Oct 21, 2017 05:55 PM
Supertractor3
Apr 7, 2017 11:16 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Ntety
Sep 2, 2015 08:39 PM
