R50/53 Engine Mounts
Old Oct 26, 2013 | 12:20 PM
khor1287's Avatar
khor1287
Engine Mounts
Im planning on replacing several engine mounts this coming week (upper, lower and passenger side). I've seen a how to on the oil filled one and everything seems pretty straight forward. However i haven't been able to find any how tos on the other mounts. It seem like they will be fairly easy too. Basically jack the car up, support the engine, move some crap outa the way, replace mounts. Just to make sure however i would be more comfortable if i could follow a guide.
Can anyone link me to a how to guide on either mount? I imagine they are fairly simple so if guides aren't available or required does anyone have any tips/tricks for me? Do i need any special equipment?
Thanks for tips and help !
Old Oct 26, 2013 | 05:31 PM
jamez's Avatar
jamez
I did my lower and passenger mounts (I went with Vibratechnics) try this article, it may help:
http://www.pelicanparts.com/techarti...eplacement.htm
Old Oct 26, 2013 | 05:34 PM
Da_Ghost's Avatar
Da_Ghost
Check the How-To section, most likely one in there. You need a E12 Torx to remove the nut holding the bottom of the upper mount. Other than that, it's pretty much straight forward, support the engine, remove the mount, replace, re-install. If you do the transmission mount, you have the remove the air filter box.
Old Oct 26, 2013 | 05:39 PM
ACallahan's Avatar
ACallahan
http://www.*********************/lib...#axzz2isWEHG4Y
Seems NAM does not like the web address I posted, ex employee thing I guess. PM and I can get it to ya.
Old Oct 26, 2013 | 05:53 PM
khor1287's Avatar
khor1287
Damn wish i had known that a few days ago when i put on my CAI. Guess ill be rly good at removing all that crap now.
Thx for links and tips !
Old Oct 27, 2013 | 06:34 AM
tbearmini's Avatar
tbearmini
Yeah, the transmission one is the hardest IMHO but it just requires removing more stuff to get at the bolts.
Old Oct 27, 2013 | 07:36 AM
ZippyNH's Avatar
ZippyNH
If you read the terms of service...
They will read the address you post in the pm...it is still not private..so much for synergy between sites....
Funny how SOME sites get ×××××× out, and some don't......
If it is the diy I am thinking of...it is a good one...
Old Oct 27, 2013 | 03:25 PM
khor1287's Avatar
khor1287
All went well enough once i ripped my passenger mount out in two pieces.....guess it was about time to replace that one .
Only problem now is the oil i found sprayed all in my passenger side wheel well, not oil from the mount i think, and on the my oil pan area . Really hoping i just parked in a puddle of it at the harbor freight parking lot and not coming from my car. I havent seen any spots where i park regularly and my levels seemed ok so heres crossing my finger on that one. Any idea where/how it might have gotten in my wheel well if it is indeed coming from me car?
Besides that all i have to worry about now is that my interior is guna rattle itself apart so any tips on quieting trim panels would be appreciated.
Thanks for all the tips and links!
Old Oct 31, 2013 | 03:54 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Inside of your wheel-well, may be a leaky strut seal or possibly oil pan gasket.
Maybe clean the wheel-well and watch it over a few days but not to panic.
Mark/Pelican Parts
888.280.7799 | 6am - 5pm PST
woodstudio
Mar 15, 2020 08:28 AM
silence2-38554
Nov 12, 2015 09:39 AM
sleek55044
Aug 21, 2015 10:52 PM
Aug 19, 2015 12:51 PM
