R50/53 Do I have to pull the Supercharger?
Old Oct 12, 2013 | 11:40 AM
tberg44's Avatar
tberg44
Do I have to pull the supercharger off in order to replace the water pump on my R53 or can I leave it on and still get the job done? Thanks!
Old Oct 12, 2013 | 12:17 PM
markjenn's Avatar
markjenn
I think you have to gain access to the supercharger which is the majority of the work. And once you're in this deep, most will want to pull the supercharger and to an inspection and oil change.
- Mark
Old Oct 12, 2013 | 12:37 PM
Cease's Avatar
Cease
Yup, while you are in there do yourself a favor and change the SC oil, you will need two bottles which I believe are 4 oz each. It's an extra few bolts and vacuum lines but worth the peace of mind that your SC gears won't run dry and cost you approx. $800-$1000 to rebuild the unit.
The water pump, thermostat and housing, hoses and SC oil are my next project. Check out Pelican Parts tech library, they have a great WP write up.
Old Oct 13, 2013 | 07:31 AM
JoeGravelle's Avatar
JoeGravelle
I recommend 3 bottles. One too use to rinse each side out
Old Oct 13, 2013 | 02:47 PM
tberg44's Avatar
tberg44
Cool, thanks guys. Would y'all recommend me doing anything else while I am in there? I just hit 86,000 miles. Is there a write up for SC oil change?
Old Oct 13, 2013 | 04:15 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Do the supercharger gaskets and the crank sensor seal, I have it all in stock if you need just call us.
Old Oct 13, 2013 | 05:07 PM
minibx's Avatar
minibx
Like Way said, change the gaskets, also Since you are changing the WP get a new part# 11517509170 CONNECTION FLANGE $18.13 with the O ring, once you take the old one off clean the matting surface with a razor blade and some kind of cleaner, make sure is nice and smooth before you put on the new flange with the O ring.
The are a few How to's around but I'm lazy, google it you'll find a few tips. It is very easy just be extra carefully not to damage the bolts by using the right tool and search the torque specs beforehand.
When I changed my oil, I realized that it was full on both ends and clean too for an 89,000 miles car but I'm not the original owner and I was in there already so why not. Good luck and double check everything.
Old Oct 13, 2013 | 07:08 PM
tberg44's Avatar
tberg44
Are these the parts you are talking about?
http://www.waymotorworks.com/superch...et-gasket.html
http://www.waymotorworks.com/cranksh...or-o-ring.html
Should I do a serp. belt too?
patsum
26
May 29, 2021 06:29 PM
StrongIslandMini
Sep 15, 2015 06:57 PM
larryd96
11
Sep 8, 2015 05:01 AM
Sep 3, 2015 03:01 PM
cw40342
Sep 2, 2015 06:01 AM
