R50/53 Where to find same factory stripes
Old Sep 26, 2013 | 07:33 PM
AZ R53's Avatar
AZ R53
Car is reaching 7 years old and the factory stripes are not quite as clean as the rest of the car. I have read in how to remove the current stripes but where can i find the same oem stripes to replace them?
Old Sep 26, 2013 | 07:41 PM
cerenkov's Avatar
cerenkov
realoem.com will have the part number, for you I chose a build date of 6/2006 if this isn't correct you can change it but for stripes I don't think it matters.
http://www.realoem.com/bmw/partgrp.d...21&hg=51&fg=25
Then click on the diagram and it will bring up part numbers and then you can order them from one of the forum sponsors.
Old Sep 26, 2013 | 09:09 PM
AZ R53's Avatar
AZ R53
Her is what my stripes look like.... Like the way they look just want new.
Old Sep 27, 2013 | 03:01 AM
cerenkov's Avatar
cerenkov
Those are the viper stripes, I like them too!
Old Sep 27, 2013 | 05:29 AM
S80's Avatar
S80
I do not believe Mini ever offered those stripes as OEM. They are aftermarket. OEM stripes are designed to be installed without cutting, fitting or stretching. The R53 hood with its pronounced hump is quite entertaining to lay stripes over. Find a good wrap shop and have them use a cast prelaminated vinyl such as 3M's 1080 series. Avery and Oracal also have a vinyl specifically designed for vehicles.
Good luck with your stripes, I think the viper stripes on the R53 is a great look. You don't see it very often.
Jim
Old Sep 27, 2013 | 12:22 PM
Yea, the Genuine MINI Dual stripes ( viper stripes ) for the hood and trunk look like this. Yours must be aftermarket.
#1 Dual Sport Stripes - White For the Hood and Trunk 51140411940
http://www.ecstuning.com/Search/SiteSearch/51140411940/
#1 Dual Sport Stripes - Black For the Hood and Trunk 51140411941
http://www.ecstuning.com/Search/SiteSearch/51140411941/
And then for the roof of the R50 and R53.
Dual Sport Roof Stripes - White 51140411943
http://www.ecstuning.com/Search/SiteSearch/51140411943/
Dual Sport Roof Stripes - Black 51140411945
http://www.ecstuning.com/Search/SiteSearch/51140411945/
Dual Sport Roof Stripes - Red 51140411946
http://www.ecstuning.com/Search/SiteSearch/51140411946/
That's pretty much all the dual stripe options for the Gen 1 MINI for the genuine MINI side.
Thanks and hope that helps.
SPORT STRIPES INSTALL PDF ATTACHED
File Type: pdf
Old Jan 12, 2014 | 03:48 PM
gary87xj6's Avatar
gary87xj6
stripes for Astro black 2006 MCS
I'm thinking of adding the viper stripes in red to my solid Astro Black MCS with no sunroof and need some input. should I do the stripes in hood and tail gate or do I need them on the roof also?
Appreciate any thoughts.
Old Jan 12, 2014 | 05:50 PM
Fly'n Brick's Avatar
Fly'n Brick
Only thing I will add to the below is to get your bonnet stripes laminated, top and boot stripes don't need it unless they all come that way anyway. I've been thru 2 sets non laminated and they got horribly bug scarred. the latest stripes are laminated, have been on a little over two years and not a mark on them. WMW and S80 are spot on.
Old Jan 13, 2014 | 11:21 AM
You must be doing aftermarket for the red on the hood and trunk. If you have a black roof I would do it all the way across. White roof , I don't know. Guess I if you would alternate with Black stripes on the roof on white, but its might be too much. I like it on the Chili Red above.
Old Jan 31, 2019 | 10:30 AM
I just added the sport stripes install PDF above because I finally found it, had a person ask in the other post about it.
Sexual Chocolate
Mar 31, 2019 08:02 PM
Dec 23, 2015 10:36 AM
M1N1M0X1E
Aug 17, 2015 09:01 PM
bctf1
Aug 6, 2015 12:55 PM
